Ignition Interlock Devices for Prius
Discussion in 'Gen 2 Prius Audio and Electronics' started by Paul Schenck, Jul 29, 2021.
  1. Paul Schenck
    Paul Schenck Active Member
    493
    270
    Fresno, California
    Recently I was asked to look into the best ignition interlock device for a Prius. Of course they all say they are; Smart Start,intoxalock, low cost interlock, etc. I wondered if any friends of Bill W had any advice?
    iPhone ?
  2. Paul Schenck
    493
    270
    Fresno, California
    It turns out there are very few alcoholics driving Gen2 Pri.
    After a lot of shopping I selected “Low Cost Interlock”
    Not because they were low cost but because their interlock device was the smallest and had the features like an app to warm it up and they hired some of the best audio experts “Audio Innovations of Fresno” to do their installs. Even so, the installation didn’t go as they had planned, singe the only Prii they had installed IID’s on were younger than 2010 and I am a Original owner of a 2005 with 614,000 miles.
    The install was estimated at $250 cash and I paid them $300 and received the white glove treatment you would expect for a $50 tip.
    What they explained was that they had to interrupt the start switch or the push button itself. And draw power (12volts) from the battery to power the interlock device.
    So, when I enter the car, or use the app, I start the IID and let it wake up for ten seconds, then give my “sample” or blow, then press the power button and the car comes to life.
    This installation does come with a caveat; on occasion I will need to give a sample to turn the car off, or the push button may not shut the car off unless I do.
    The cord draping out from under the dash is the most annoying part of it. I may ask for a modification and have it mounted I. The center counsel arm rest
    As usual I’ll post pictures later
    iPhone ?
    burrito likes this.
  3. burrito
    burrito Member
    264
    95
    You can probably just tape it. You might be able to stuff it up over the plastic down there and tape it to the inside.
    With the tip you paid, though, they should be able to care of it for you in a few minutes.
  4. Paul Schenck
    493
    270
    Fresno, California
    Quick note to installers if they do the same the car will only start when the key fob is NOT inserted in the slot ! Keep it in your pocket and if you do not have the feature on your Prii I’m not sure it will work.
    iPhone ?
Loading...
