illuminate the joystick shifter?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by windstrings, Sep 2, 2009.
  1. Mark57
    2,945
    2,739
    OK
    I still smile at mine when I pull into a dark garage or similar area and i notice the glow. ;)
  2. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    We need to see about the luminous stuff......
    I need a radioactive stick shift!
  3. Mark57
    2,945
    2,739
    OK
    Don't forget to order the optional lead jock strap.:D j/k
  4. lupicia01
    lupicia01 New Member
    San Jose
    Thanks guys really cool.
  5. BlueSmoke
    BlueSmoke New Member
    27
    Chicago Suburbs
    This is a very cool thread. I'd be interested in doing this myself. I have a 5 day old 2010 Prius IV. I love it.
  6. Solscud007
    Solscud007 New Member
    59
    Nyack, NY
    Any recommendations where to get tritium sticks?
  7. windstrings
    6,280
    378
    Central Texas
    Everytime I check they are still expensive.... I suppose if you wanted to spend 100 to 300.00 you could throw a few into the bottom "when turned upside down" and pour epoxy in to hold them. Could be an expensive project but possible.
    For Sale: Tritium Vials
    * 23mm x 3mm vials @ $16.00 each. Available in Green, Purple, Yellow, Orange, White, Pink, Red, & Ice Blue
    Tritium Disc:
    1.5mm x 5.5mm Green cylindrical tritium vials in Green Glow-in-the Dark circular case with adhesive back at $11 each.
    http://web.singnet.com.sg/~desertmn/IMG_1238.JPG
    If you scroll to the last page they are still selling.
    Here is another link
    TiGlow titanium glowrings RE-OPENED
    *CLEAR* MERKAVA NiTE GLOWRINGS ~ 7 Colors to Choose From !!
    Here are some that are 22.00.. more money but bigger...
    For Sale : MERKAVA I & II Tritium Glowrings Part 3
  8. Solscud007
    59
    Nyack, NY
    Thanks. I was hoping for a source that wasnt CPF nor overseas.
  9. windstrings
    6,280
    378
    Central Texas
    Humm.. good luck... I haven't been able to find any.... seems anyone who sells that stuff knows to go to cpf as there are most of the buyers for such.
    You would have to find an industrial use link and then be able to provide credentials proving you were using it for a legit reason thats possibly trackable.
    If you could find a slick way to power it.... a few leds thrown in would sure be much easier!..... they could be on anytime the car is on for that matter as they shouldn't go bad from overuse.
    I've thought about cramming a strip of those led floorboard lights you can buy into the shifter if you could find a thin enough one to fit...... I'm sure that would look quite jazzy as there would be many lights reflected through the top blue lens.
    Running the power wire inside the shifter bar would be the slickest..... I just haven't wanted to tear into everything to do it.
    would be cool if you could get this into the shifter.. its 20" long and .3" wide
    http://cgi.ebay.com/ebaymotors/Audi-style-20-side-shine-SMD-LED-Light-strip-White-L68_W0QQcmdZViewItemQQ_trkparmsZalgoQ3dLVIQ26ituQ3dUCIQ26otnQ3d6Q26psQ3d63Q26clkidQ3d5997024270717939454QQ_trksidZe17001Q2em7QQcategoryZ33713QQitemZ120591299012
    http://www.ledoption.com/eBay/Listing/LP_New/Other/strip-02.jpg
  10. a1rjumpman23
    a1rjumpman23 Junior Member
    75
    Very cool thread! Will be doing the same to mine.
  11. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    According to the Glowpower site Glow in the Dark Charging Lights , UV LEDs would work very well for charging the glowpowder. What if the overhead console LED was replaced with a UV LED? That should reduce the visible lighting level and increase the glow emitted by the glowpowder.
    2 people like this.
  12. Mark57
    2,945
    2,739
    OK
    Excellent catch and a great idea. I'll look into it further for mine.
    Here's an interesting excerpt from your Glowpowder site link above . . . . .
    A black light shining on a glow surface for 30 seconds will cause that surface to be 10 times brighter than a flashlight on it for 6 hours.
    Here is a simple list of bulbs in order from least to most efficient:
    White LED's
    Blue/Purple LED's
    Incandescent - standard light bulb
    Compact Fluorescent or CFL - spiral tube, screw-in
    Fluorescent Bulbs - long tubes
    UV LED's
    Black Light Tube
    Direct Sunlight
  13. itonarely
    itonarely Junior Member
    36
    Miami
    Powder arrived this morning and is now in the shifter.
    Going out tonight so I'll see how well this project worked out for me.
    I went with the cream colored glow powder (purchased on Amazon) which glows blue.
    The process was very easy (and still I made a bit of a mess) and only set me back $10 or so. Wish me luck.
    Now, what do I do with the remaining powder...?
  14. NickinVA
    NickinVA Not saving the world, just gas
    Virginia
    Well? :confused:
  15. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    Feed it to the dog and get a UV flashlight, find a fresh dog log and tell your wife "The dog is radioactive! Call the vet!"
  16. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    thats pretty cool .. never seen anyone play with that stuff before!!
  17. 2012PriusBoy
    2012PriusBoy New Member
    Crawfordsville, Indiana
    Maybe a Blue Tooth Blue LED somehow???
  18. 2012PriusBoy
    No...If you Got the Shifter off that a Plus I'd research Blue Tooth LED's for Example there has to be a way we can Illuminate Shifter with a LED somehow without wires Keep at it don't settle for glow paint what a mess hate to have to purchase a shifter if you screw it up....your on the right track stay with it...perfect it
  19. 2012PriusBoy
    No...If you Got the Shifter off thats a Plus I'd research Blue Tooth LED's for Example there has to be a way we can Illuminate Shifter with a LED somehow without wires Keep at it don't settle for glow paint what a mess hate to have to purchase a shifter if you screw it up....your on the right track stay with it...perfect it
  20. 2012PriusBoy
    "If" I can Order a Spare Shifter I'll Experiment with it until I've perfected it with a Illuminated Blue LED. I have some Knowledge Of LED's & Blue Tooth's Devises so I'll stay at it and on it Until Mastered Perfectly. Indeed that a Small LED would need to be placed at Base Of Shifter thats Easy. I just need to decide which technology would best be suited to illuminate Shifter Wirelessly and with all the different Products & Technology out these days we should be able to Get it Mastered Flawlessly... I'll Keep you Folk's Posted & Post Pictures just Bare with me I'll make it happen....
