I'm a Californian: Got a Prius to replace MINI
Discussion in 'Gen 3 Prius Main Forum' started by misstenacity, Jun 5, 2018.
Tags:
  1. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    You mean something like:
    [SARCASM] Does the Prius have a 2-stroke engine? [/SARCASM]
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Too much work, borderlining to html 1.0 now :p
  3. orenji
    orenji Senior Member
    5,887
    3,490
    How about "JK" that would be helpful, so we don't waste a lot of time trying to ponder ones statements! :)
    mjoo likes this.
  4. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Congratulations and welcome to PC!
    If you are tenacious (pun intended) I would swap the EGR components and intake manifold with cleaned ones. One thread discussing this topic is:
    EGR & Intake Manifold Clean Results
    Also adding a catch can to your PCV (very easy to do when the parts are off for cleaning). This will help prevent the headgasket problem (thousands of $$) later on and keep your fuel economy high.
    Raytheeagle and misstenacity like this.
  5. misstenacity
    misstenacity Junior Member
    28
    Utah
    Wow, definitely will check out all of that info. Maybe I can do it myself. :) I got a decent deal on the car so I don't really want to "undo" that with lots of additional money out the gate. But if it will save headaches later, that's something else entirely. Prevention!
  6. misstenacity
    28
    Utah
    Side question!!! So my car does not appear to have one of those emissions sticker things. The label that is supposed to say if the car is OBDII compliant, yadda yadda. I looked all over the engine compartment, under the hood, even back by the battery. Nothing.
    Hints? This was an AZ car when first sold. Did I just buy a huge problem here in CA? Hopefully it's the dealer's problem and not mine, as they are still trying to get the car registered. Hmm.
  7. JC91006
    16,939
    8,647
    You probably had your hood replaced. All prius cars are California emissions compliant
    Raytheeagle likes this.
  8. misstenacity
    28
    Utah
    OH. Well..... that would be unexpected. {edited!} There is an accident on the carfax but no deets, and no lasting/serious damage found during the inspection, so I guess the hood was part of the repair. The hood currently has a bunch of rock chips, so I guess the car has been fine for quite a while now.
    As long as it registers (and re-registers), I'm copacetic.
    #28 misstenacity, Jun 12, 2018
  9. PokerMunkee
    PokerMunkee Junior Member
    34
    23
    Denver, CO
    I'm a new gen 3 owner too and also have a MINI. I have a 2008 S convertible M6. I'm not getting rid of it, need something sporty to drive on the weekends! The Prius feels like a boat compared to the MINI, ha!
    misstenacity likes this.
