I'm buying a used steering rack...and ECU?
Discussion in 'Generation 1 Prius Discussion' started by bjustin, Mar 22, 2010.
  1. bjustin
    bjustin New Member
    27
    seattle
    2002 Prius
    i found a used steering rack online that I intend to have a shop install.
    Does it come with an ECU or do you have to buy that separate? The online site does not specify... the following items are listed and sold separately:
    steering rack
    ECU right side dash - engine control
    ECU part of battery pack
    Which items do you suppose I need to buy?
    Thanks!
  2. Patrick Wong
    18,210
    6,513
    If your problem is a jerky steering wheel, typically that will be solved by installing a new steering rack. No other electronics need to be replaced.
  3. tochatihu
    tochatihu Senior Member
    9,852
    3,814
    Kunming Yunnan China
    2001 Prius
    This decision may already be made, but given a choice, I would want the donor vehicle to be 2003 model year. There is some reason to believe that they made them better towards the end of the model run.
    Our Patrick put a copy of SSC YO5 online - it includes some helpful information if the shop involved does not have experience with steering replacement. Is this something you'd need bjustin?
