I'm curious - how many different hybrid drives does Toyota make?
Discussion in 'Prius c Main Forum' started by goldnrod24, Aug 9, 2017.
  1. goldnrod24
    goldnrod24 Junior Member
    27
    Michigan
    2016 Prius c
    I've poked around here at some of the technical info, but am still curious. Since Toyota makes so many hybrid vehicles, from sub-compacts to sedans to CUVs and SUVs, how many different drives do they make? I ASSume that a C doesn't need the same driveline as a Camry. Yes, the ICE would be different, but what about the hybrid components?
    Any ideas out there?
    49,500
    I think they are the same, of the same generation, but in various sizes.
    Although, they added a one way clutch to prime, which I believe is unique.
  3. kevinwhite
    kevinwhite Active Member
    331
    199
    Los Gatos Ca
    Wikipedia has most of the different variations described although it is getting out of date. The larger vehicles have more complex arrangements than the Prius because the simple one with a single PSD has a limited speed range.
    Hybrid Synergy Drive - Wikipedia
    kevin
  4. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I thought I remember hearing when the C came out it used the same size engine as the Gen.2 Prius? Is that still true?
  5. kevinwhite
    331
    199
    Los Gatos Ca
    Yes - 1500cc but the hybrid system was downsized - it only has 144volt NiMh hybrid battery.
  6. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Here's the hybrid-specific gearboxes that I'm aware of existing, produced by either Toyota or Aisin, using Toyota nomenclature when available, and current production gearboxes are bold:
    P110: Gen "0" Prius (Gen 1 pre-refresh, Japan only)
    P111: Gen 1 Prius (post-refresh)
    P112: Gen 2 Prius
    P210: Gen 1 Estima Hybrid (true CVT, not a power split device - they didn't think a power split device would work well in a van at first)
    P310: RX 400h, 2010 and older Highlander Hybrid
    P311: All Camry Hybrids before 2018, Gen 2 Estima Hybrid, HS 250h, Sai, ES 300h, Avalon Hybrid, Alphard/Vellfire Hybrid
    P312: Nissan Altima Hybrid (no, really)
    P313: 2010+ RX 450h, 2011+ Highlander Hybrid
    P314: NX 300h, RAV4
    P410: Gen 3 Prius, Prius v/a/+, CT 200h, Auris Hybrid, Noah/Voxy/Esquire Hybrid, Mazda Axela (aka Mazda3) Hybrid
    P510: Aqua/Prius c, Yaris/Vitz Hybrid, Sienta Hybrid
    P610: Gen 4 Prius, C-HR Hybrid
    P710: 2018+ Camry Hybrid
    L110: GS 450h, Crown Hybrid models
    L110F: LS 600h (just adds AWD)
    L210: IS 300h, RC 300h, GS 300h
    L310: LC 500h, coming LS 500h (may be called L310F in that application)
    Aisin HD-10: Ford Escape/Mercury Mariner Hybrid
    Aisin HD-20: Ford Escape/Mazda Tribute/Mercury Mariner Hybrid, Ford Fusion/Mercury Milan/Lincoln MKZ Hybrid
    Also worth noting that the Mirai's motor/transmission is essentially a derivative of the P310/P313, but without the power split device or MG1.
  7. goldnrod24
    27
    Michigan
    2016 Prius c
    Wow. I never would have guessed.
    Thanks.
  8. Rmay635703
    Rmay635703 Senior Member
    2,594
    1,612
    Somewhere in Wisconsin
    2013 Chevy Volt
    6D6BDD41-EA15-4524-AC3D-940ED2FCE759.jpeg Out of curiosity what code does the Mirai transaxle have?
    Q312?
    also was a Mirai ever torn down by one of the popular channels?
    thanx
    #8 Rmay635703, Nov 4, 2019
  9. Elektroingenieur
    2,515
    3,259
    Three Touring
    As I mentioned in the other thread, it’s a Q410. The New Car Features book (more info) for the Mirai has some diagrams and basic information.
    I haven’t seen anything like that. Toyota has released some videos of the production process, though.
  10. ChapmanF
    15,630
    Might be better to say "belt CVT". There's nothing any more or less "true" about using a belt to achieve Continuously Variable Transmission than using planets, motors, and switches to accomplish the same task.
