I'm curious; if the engine runs out of oil, will it shut off automatically?
Discussion in 'Gen 2 Prius Technical Discussion' started by herqulees, May 22, 2015.
  1. Mendel Leisk
    41,459
    You'ld think, and I'm not sure why, but without that 5 minute hiatus it's always smeared, no matter how long it's sat.
    Try both methods.
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    When I change the oil on my cars I just leave the dipstick out for a few minutes before checking it again. Helps to allow the oil on the dipstick tube to drain
  3. Skibob
    2,912
    1,505
    Northern California
    Do you mean if you add oil? When I check mine in the morning before starting the car it is not smeared.
  4. Mendel Leisk
    41,459
    I find if I pull, immediately replace and pull the dipstick again, for a check, there's oil smeared a long way up the edges, any scenario.
    I do just that, and manage to decipher it, but a 5 minute wait before the second insert dispels most if not all of the smearing.
  5. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    Yeah, I usually check it in the morning before heading out. As long as I can see it, everything is good. :LOL: It's never low.
    Never had any sludge trouble (that I know of) with the 2005 Camry. Drove it for 11 hears, zero problems. Never burned oil. Wish I had kept that car a little longer.
  6. Starship16
    1,348
    1,455
    Beach Christmas
    I think Mendel mentioned that the Gen4 dipstick is shaped different?
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Check it first thing in the am after its sat all night all the oil stored up in the vvt vane system will have drained back and the dipstick will be nice and clean.
    padroo likes this.
  8. Starship16
    1,348
    1,455
    Beach Christmas
    You would think..... :) Agreed, and sounds easy, but I always have the "mystery smeared dipstick."
  9. Mendel Leisk
    41,459
    Yeah just occurred to me, @Skibob 's second gen, I'm third, and @Starship16 's fourth: maybe second gen dipstick is less problematic. Third and fourth gen engines are more-or-less interchangeable (per @Ragingfit), but second gen is different displacement, for starters.
    Starship16 likes this.
  10. Starship16
    1,348
    1,455
    Beach Christmas
    I gotta laugh at this. Never had an issue in the past with any other dipstick. Just a Prius.:LOL: And the dipstick is perfectly straight, but it must turn or twist in there somewhere.
    The car has been parked all night and all morning. Just did a first-pull check of the dipstick. The oil is smeared about 1.5 inch above the full mark. Wiped, waited 5 minutes, re-inserted. Pulled it out, and.... :( Not quite as bad, but still spotty and smeared.
    My Toyota manual says to check oil when engine is warm. Wait 5 minutes after shutting off power, and check.
  11. Mendel Leisk
    41,459
    I'd suspect it doesn't make much difference; try and see.
  12. Starship16
    1,348
    1,455
    Beach Christmas
    I did.
    It didn't.
    :ROFLMAO:
