I'm installing a tachometer
Discussion in 'Gen 2 Prius Technical Discussion' started by rustystew, Apr 30, 2011.
  1. rustystew
    rustystew New Member
    Galisteo NM
    So I picked up a tach to install this weekend.
    I'm scared.
    I don't know much about electronics, but the guide seems pretty clear:
    http://techno-fandom.org/~hobbit/cars/tachack/
    I'm not convinced I want to do a permanent install yet.
    Basically I feel like I'm going to explode or my car will render itself useless in a very expensive and/or life threatening mistake.
    Should I disconnect my battery before dicking with it, or will everything be ok?
    Maybe I should return the $30 tach and save up for a scangauge II (*cough never cough*). I just didn't want to spend $160.
    Midnight...my mind is gone. Good Night.
  2. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I think the regulars will suggest ditching the tachometer and buying the SGII. You'll get much more bang for buck and you don't need to cut any wires.
    49,797
    doesn't look too hard, what tach did you buy and how do you know it's sensitive enough?
  4. brick
    brick Active Member
    1,083
    78
    Upstate NY
    Not me! An analog needle can be read at a glance, which is important for feedback that you are likely to use often. I look at engine RPM all the time. The digital ScanGauge display is better suited to slower moving feedback that you need less frequently. It's great for things like EV button condition, engine temperature, etc.
    I used Hobbit's page as a guide and didn't have any problems. That was four years ago and it still works. My only wish is that I had bought a better-quality tach, though my cheapo does get the job done. Just go slowly and if in doubt, stop and ask for help.
  5. dogfriend
    7,512
    1,188
    Carmichael, CA
    Did you explode yet? :madgrin:
  6. rustystew
    Galisteo NM
    I bought a sunpro super tach II. I don't suspect it is an amazing tach. Just something to get me in the ballpark. To be honest with you I DON'T KNOW if it will work. But it does say it will work with a distributor type or distributor-less ignition which seems like it must be able to read off an electric signal of some type. And it says it works on 4, 6 or 8 cylinder engines, and hobbit says to set it for 4. So based on my limited knowledge these two specs seem to suggest it probably will work...to me anyway.
    Oh yeah, and I was kind of serious about this question:
    Brick, did you use hobbits suggestion for the power supply to just hook it up to the cigarette lighter adapter for power? Or did you hardwire the power to the car? (if the later, could you help me figure out how to do that?)
  7. rustystew
    Galisteo NM
    So a couple other questions for confirmation. The tach says it is designed for us on 12V negative ground four cycle automotive type engines. Not for positive ground systems, 2 cycle engines, aircraft or marine applications.
    After poking around google I have come to the conclusion that the prius as are all modern US cars negative ground. Is this correct?
    Also here are my thoughts on placement.
    I'm pretty sure this would be the best location for the tach being that it is close to road line-of-sight, but I don't have to run ugly wires down the middle of my console or drill holes. Initially I will probably use a sticky double stick tape or foam tape to hold it in place until I decide that it really is a good spot for it. This is to the left of the steering wheel.
    I am thinking the wires can run down along the left edge of the air vent. It looks like there is a bit of a groove that it will fit nicely into and not look hideous.
    As for the ground, I figure while I'm over here I can just tap the ground to this bolt here connected to the door frame. Do any of you see any issues with this? Potentially exposure to water could be an issue? Would it damage the weather stripping? Would it just not actually work as a ground?
  8. direstraits71
    direstraits71 Member
    367
    64
    Central Coast California
    That is correct.
  9. dtuite
    dtuite Silverback
    182
    31
    Redwood City, CA
    In a car in which the prime mover is an electric motor, what does a tach on the ICE tell you? I understand about the ICE's torque curve and power curve -- so you've got an RPM number for peak torque (acceleration) and peak power (sustaining velocity against drag and hills), I suppose. Except you've got an ECU between your foot and the injectors that has its own ideas about ICE curves. But you have to do your own P&G calculations if you want to do control down to an RCH -- so what does knowing the ICE RPM give you?
    I agree about analog displays. At a pilots' organization meeting this week one of the flight instructors said that accident data was showing more crashes in planes with glass cockpits than in planes with old steam-gauge six-packs. (Of course that's skewed by other factors like the aerodynamics of newer planes, which just happen to have glass cockpits.
    As far as I know, if you do't have a British car from the 1950s, you are extremely unlikely to have a positive ground. (Don't know about Ladas and Trabants.)
    RCH: an engineering term for an extremely small measurement.
  10. bisco
    49,797
    it tells you the sweet spot for best acceleration gpm's.
  11. bisco
    49,797
    nice pics. sorry, i don't have any answers, but i'm watching with great interest. be patient, i'm sure some of the techs here will help you out.
  12. rustystew
    Galisteo NM
    Dtuite, here is a link to a pretty detailed explanation of it all. At least this why I am doing it.
    Sweet spot refinement
  13. brick
    brick Active Member
    1,083
    78
    Upstate NY
    Sorry for the way late reply. I just wired it to the lighter since I had to run the other wires in that direction, anyway. I have the same tach and it definitely works. Do disconnect the 12V battery before doing the work just to be safe. It might not be strictly necessary but an accidental short across the wrong ECU wires could ruin your day (and ECU). That's one of those low probability but severe consequence type events that you may as well prevent.
    Your placement looks good, very similar to mine. You will need to make some kind of bracket, since it comes with something designed for a steering column. If you can fabricate a simple bracket, 3m "Dual Lock" fasteners are the absolute best non-permanent solution that I have found so far. I get it at Target. I'll try to post a pic of my mount later in case you want some inspiration.
    Mine seems to be a couple hundred RPM off compared to the scangauge but it gets the job done and hasn't failed. I don't think the discrepancy really matters since you just need a reference.
  14. brick
    brick Active Member
    1,083
    78
    Upstate NY
    Here are pics of my own install. Like I said, that Dual Lock stuff is great. I fabricated the bracket itself from a sheet of lexan, which is available at your local home store. Just cut out the shape you want (a Dremel or equivalent is helpful here) and make the bend with a gentle application of heat. I like to pass this stuff back-and-forth a few inches over a candle, which I find gives me enough heat and good control. It will reach a magic phase transformation temperature and bend right over. Then just hold it in place for a few seconds as it cools. I'm sure there are slicker options but this was easy.
  15. brick
    brick Active Member
    1,083
    78
    Upstate NY
    Oh, one last thing. The wires can be tucked behind the weather stripping that runs down the door jamb. Also, I seem to recall needing extra wire to get all the way to the ECU, which is all the way on the right behind the glove box. Tucking all the wires behind the dash will probably be a pain. I don't recall exactly how I did it but I'm sure you will find a path. Zip ties are helpful to keep wires in place.
  16. oliveoil
    oliveoil New Member
    Indiana USA
    It only goes to 8K ?? Might be ok for city driving...
  17. rustystew
    Galisteo NM
    I'm going to make an attempt this weekend. See what happens. Thanks for the tips and photos brick! Also brick, could you inform me where you hooked up the ground (maybe with photos too?) and how you chose to hook up the signal wire. If you spliced it into the wire, what technique did you use?
  18. brick
    brick Active Member
    1,083
    78
    Upstate NY
    I went out to look and I would have to tear things down a bit more than I want to to get decent pics. But for the ground I think I just tapped the lighter socket same as the 12V+. For all connections the simplest method is to use wire taps. They can be a little finicky if you don't crimp them down far enough, but it gets you out of cutting important wires that you then have to splice back together. Just be careful not to tug too hard on anything while making your connections.
  19. brick
    brick Active Member
    1,083
    78
    Upstate NY
    Still alive?
