I'm new, but owner since 2012
Discussion in 'Newbie Forum' started by Market05, Feb 27, 2017.
  1. Market05
    Market05 New Member
    27
    Western Maryland
    want to stay a prius owner and going through a rough patch! About a month ago, I had the "triangle light" go on indicating a problem with the transaxle. I paid someone to install a used only to have it happen again. This time I'm doing the work and got the unit out, exchanged, and now need to put it back in. It's been a "bear" of a job, but slowly getting there. Anyway, hello all! Once fixed, I'm entertaining upgrade to Prius gen 3 (mine is a 2005 gen 2).
    RCO likes this.
    52,791
    welcome!
    how many miles on her? all the best with your repairs and next vehicle!(y)
    RCO likes this.
  3. Market05
    Market05 New Member
    27
    Western Maryland
    I'm right at 105,000 miles. I like the look of Gen 2 more than the newer ones, and was going to drive it at least another 100k, but since she's 12 years old, that may not be very practical.
    RCO likes this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    That's pretty low miles for an '05. Mine had 149,000 when I traded it in late December. There must be something about the thought of a car being 12 years old that makes a person long for something newer. LOL! Hope you can get it all put back together and running like a top for the next owner.
    RCO likes this.
  5. ETC(SS)
    7,511
    Greetings and Welcome aboard!!!
    You're the first person who I know of that's on their third transaxle!!!
    That's very interesting considering your low mileage.
    Maryland is a CARB state according to the Googles, so this may be a good reason for you to stay in a qualifying vehicle under 10y/150,000m.
    I'm not sure that the T/A would be covered as a hybrid component (It should be IMHO because of how the HSI system works) but since I live on freer soil I'm not protected by CARB.
    You might be.
    Good Luck!!!
    RCO likes this.
  6. Market05
    Market05 New Member
    27
    Western Maryland
    Thank you ETC (SS) that's very good to know. I'm just hoping that the diagnoses is correct in that I've seen threads on this forum where a bad traction battery will throw all sorts of codes. I think after getting her back together I will just drive her "sparingly" and put her up for sale. I will definitely tell the new buyer the history of course.
    RCO likes this.
  7. ETC(SS)
    7,511
    I'm thinking that the smaller (12v) battery might do the same thing.....
    Good Luck!!
    RCO likes this.
  8. Market05
    Market05 New Member
    27
    Western Maryland
    Well, that should be relatively easy to check out. Hmmm....
  9. Market05
    Market05 New Member
    27
    Western Maryland
    Okay got a new 12v battery and replaced transaxle again! Seemed to be running well until at the end of my commute, after climbing a mountain, I got the dreaded Red triangle light again. Put my scanner on it and it indicates a P0A90 code with DTC 0 again. So I'm sick and feeling really discouraged at the moment. Would the inverter cooling pump cause this? If so, why aren't there more codes showing up? Maybe I should just "bite the bullet" and trade her in as is...
  10. jerrymildred
    11,517
    14,167
    Tampa, FL
    RCO likes this.
  11. Market05
    Market05 New Member
    27
    Western Maryland
    Well the HV Control ECU would be the least expensive, everything else has to do with the motor and damper and they all looked alright. Harness and connectors all seemed to check out also.
  12. Market05
    Market05 New Member
    27
    Western Maryland
    Is the HV Control ECU located under the glove box, and do you need to remove the high voltage plug to change it? I've found them online for about 30-40 bucks!
  13. Market05
    Market05 New Member
    27
    Western Maryland
    Any information on accessing the HV Control ECU would be appreciated. The Haynes manual describes an ECM where you have to tear apart the entire dashboard to access it. Is this the same component?
  14. jerrymildred
    11,517
    14,167
    Tampa, FL
    On a Gen 2 the ECUs are more or less behind the glove box and low. Getting to where you can see them and unplug the connectors isn't bad. No need to remove the upper dash. I never looked to see how to get my ECUs out, but things are packed pretty tightly in there. I was just accessing the connector on one of them to install an EV button.
    #14 jerrymildred, Mar 11, 2017
    RCO likes this.
  15. Market05
    Market05 New Member
    27
    Western Maryland
    I got the ECU disconnected and 1 out of two of the nuts out. I only have one more to unfasten, but it is deep underneath the dash and can only barely get one finger on it. I just bought a "swivel" 1/4 inch drive extension, and I think that will give me the torque and flexibility to access it. Anyway, I'll be finding out shortly when I get home in another couple hours. Thanks everybody for all your help!
  16. Market05
    Market05 New Member
    27
    Western Maryland
    Got the HV Control HCU out last night. Went ahead and ordered one online and it will be here Monday (dang it is going to take a week to get here). It won't be long now before I find out if this does the trick (or not). Looking back there was no indication that I was having trouble with the Transaxle, no noise or slipping ... To all of a sudden start having transaxle issues seems a bit strange. I changed the fluid at 80k miles, so I know it hasn't been abused. Just a warning to everyone that takes stock in the Dealer's technical evaluation. They told me "code indicates a transaxle problem, give us around 5K we will take care of it and go from there"....
    RCO likes this.
  17. Market05
    Market05 New Member
    27
    Western Maryland
    After reading about the Gen 4 Prius. I'm leaning towards either waiting for a 2016 Econ to come down in price to the 16k range (fall this year or early next year), or waiting 2-3 years for a Prius Prime to get there. Thoughts?
  18. Prodigyplace
    12,710
    11,848
    Central Virginia
    The 2017 have many safety features as standard that are not available on the 2016 Two or Eco. The Two has a spare tire, rear wiper, and the proven battery technology used in all the previous US generations except the plugin.
    Just additional food for thought.
  19. Market05
    Market05 New Member
    27
    Western Maryland
    As for safety, I ride a motorcycle, so everything about having 4 walls and a roof is an upside for me. I just wonder if I should wait for the 2017, since 2016 represents the first year of the technology. They do such a good job though, the old adage might not apply here (about waiting after the first year of new tech). I am starting to think waiting will be the best option. I guess it will depend on if I can fix my 05...
  20. Prodigyplace
    12,710
    11,848
    Central Virginia
    Apparently, they also improved the headlights for 2017. The IIHS test results show less glare than 2016 and an improved score.
