I'm new to Prius and I have a question on temperature
Discussion in 'Newbie Forum' started by tanglai, Apr 9, 2011.
  1. tanglai
    tanglai Junior Member
    Caifornia
    Hi all,
    I got a new 2011 Prius just a few days. It sure takes some adjustments to get used to the car because this car is taller than my previous one. Also, I am not able to see the front of the car from the driving position. I still like the car though. :)
    Here's my question: I feel relatively warm air flowing in from the vent while the outside temperate displayed says it's 45 degrees outside. I tried the up and down temperature buttons but they don't work unless I am using the Auto mode. Is there a way to adjust the temperature when the Auto mode is off?
    Thanks,
    Tang
  2. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    With the auto off......select a fan speed...either up or down. It will show you the heater choices.......then select the down arrow on the temp buttons. Go all the way to low...then you can select off again. That should take care of your problem.
    Enjoy your new ride !!!!!!!
  3. tanglai
    Caifornia
    Wow, that's a quick reply! Thanks.
    Does it mean the temperature coming in is now the same as the outside temperature when the temp button is pressed all the way to "Lo"?
    Also, the fan is on with this setting. If I press the Off button now, will the temperature remain the same?
  4. hill
    8,757
    Yep
    . . . . and welcome to PC
    :welcome:
  5. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Congrats on our new 2011 Prius and welcome to PriusChat. Be sure to read your owner's manual and search the forum for how-to's, tips, tricks and answers.
