I'm pretty happy with my Prius Prime. Just got 1000 miles On a tank of gas.
Discussion in 'Prime Main Forum (2017-2022)' started by Terry Nyberg, Feb 15, 2017.
Tags:
  1. Terry Nyberg
    Terry Nyberg Junior Member
    Denver
    The dealer we purchased from, and others have told us there is no break-in period for the ICE. We specifically asked this as the first driving was from NY to Colorado, about 1900 miles.
  2. Mendel Leisk
    41,475
    It's kinda funny in my post #13: Toyota doesn't explain the rational for either of the bullet points. The first is for brakes, the second for engine. But it'd be nice if they'd say.
    @Terry Nyberg : regardless of your dealership's statement, Toyota says there's a break-in period. But: if you abide by speed limits, avoid drag racing, and drive in varied conditions, your fine. The one sneaky one: driving under speed/rpm for protracted periods. You want to vary engine load, helps break-in.
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I don't like over analyzing things. It's 1000 km to break in the engine. If you never run in HV mode then your engine will never completely break in. That's hardly a problem as the fix would be to press that HV button.
    If you think 300 km ICE intervals are short, try 200 km in the PiP.
  4. Prodigyplace
    12,567
    11,781
    Central Virginia
    Perhaps they need one of these.
  5. bisco
    51,961
    i thought i read the ice comes on every 200 miles. pip is 124. if your ice came on, your mpg would drop from 199.9.
  6. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    That's impressive. What's the EV/hv Ratio? Of course, this doesn't mean you can drive 2/3 across the USA
    in Hybrid.
  7. Andyprius1
    2,327
    859
    Cool CA
    Yes all Prii are sensitive to various factors which can cause the engine to come on. Max pedal, Temp, Load.
  8. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
  9. MNdriver
    MNdriver Senior Member
    549
    577
    Uh... you’ve seen Prime commercials?
  10. priuscatprimeguy
    2,730
    2,640
    I have been getting a lot of Prime sponsored posts on Facebook:D
  11. MMBH
    MMBH Member
    155
    43
    Where do you find that ration?
    Andyprius1 likes this.
  12. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    In the middle screen, use the left or right button to go to i, use up or down to go to Drive Monitor. It will show your EV driving ratio. You can hit Trip on the left side of the steering wheel to see after start, after reset, Trip A, Trip B.
    MMBH likes this.
  13. Andyprius1
    2,327
    859
    Cool CA
    My reply was to yoyoman. Somebody’s quoting out of context
  14. Tideland Prius
    16,559
    That doesn't mean you can't help him lol.
    The EV Driving Ratio is on one of the Drive Monitor screens.
    Select the "i" menu (Information) using the left/right arrows on the steering wheel
    Then scroll up/down until you get the Drive Monitor
    MMBH likes this.
  15. MMBH
    MMBH Member
    155
    43
    Ty for explaining how to find that ratio! I need to see what mine is.
    My Prime Premium just turned 1000 miles this week and still have an estimated 160 miles to go before needing to fill up. (I still have just under a half tank of the original that came with the car back in mid-January.) I’ll have to set up the Killawatt meter to see how much power it’s drawing and go back and compare the bills to see how much it cost in electric vs gas pricing for that period. (I did not drive it much this winter and on,y just started driving it more regularly at the end of March and then it was in the collision shop at the dealer for 3 weeks and just got it back again the week before last.)
