I'm sure this has been asked but.....
Discussion in 'Gen 2 Prius Technical Discussion' started by striker308, Aug 17, 2010.
  1. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    ok I did a search and came up with nadda.
    has anyone tried taking a battery out of a wreck and just running it in parralel with the original? (hybrid)
    if so what did you end up with?
  2. vertex
    vertex Active Member
    672
    143
    new york
    2018 Prius Prime
    There is no point in doing that unless you can make it plug in. Charging both batteries takes more energy, so you have a 0 net gain. In EV mode, you would get more range, if the batteries are fully charged. If you make it plug in, then you have something. Several PCers have done this.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Well you would gain extra regen capabilities. If you live on a mountain like myself, it would be worth it. I fill my car from empty to full (well 40% to 80%) and have another couple miles of downhill steep grades to go. Extra batteries would allow extra storage, increased fuel economy. Plugin would enhance that. But this is a very limited scenario I am sure.
  4. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Just curious, what would that do? Add another mile to EV...? OOPS! I'm in Gen III mode. :rolleyes:
  5. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    The problem is the computers can't monitor both batteries. So you'd need new software to accomplish that. The computers -MUST- know exactly what is happening to make the HSD function correctly. I suppose you -could- wire it up so the monitoring takes the average of both packs, but it wouldn't be a trivial job. Then you'd have to figure out how to equalize the current flow to/from both packs.
    Even Toyota doesn't try to do this. In the Plug-in Hybrid they switch from pack to pack rather than try to operate them in parallel.
  6. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    Hobbit did a presentation at Green Drive Expo again this year. I think it was Hobbit's presentation; they all blend together.
    Someone did exactly this. He monitored the charge capacity and noticed that it slowly started creeping upwards. As he put it, "the car was learning that there was additional capacity to be used."
    I wish I could remember exactly who was talking about this.
  7. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    In the early days of Hymotion and such, there were folks in California that were learning how to hack the battery codes. I can't remember their name, but they were experimenting with different battery types, and I think Hymotion picked up some of their knowledge and applied it to Lithium and made a viable business out of it. They had a discussion page that was rather interesting, but the name just isn't coming to me right now.
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Simply connecting two battery packs in parallel is a ticket to disaster. Batteries must be carefully matched to work in parallel, otherwise one battery drains the life out of the other. With older chemistries you could get away with a simple parallel connection, but not with most of the new types of batteries.
    Tom
  9. orlando54
    orlando54 Junior Member
    Whittier
    Hi all. this is my first time in the Prius chat so here goes: How do you find a mechanic who can install the ev mode bypass in your prius. I've heard there is a way to fool the prius into staying in "electric mode" as long as possible delaying the activation of the combustible engine.
  10. qbee42
    18,058
    3,074
    Northern Michigan
    Anyone can do it, as long as they can install a switch into the dash. Your Prius has EV mode built in, but it doesn't come with a switch for it in the U.S. You buy a switch, remove the blank in the dash, install the switch, and wire it to the proper connector. I would think any car audio place could do it for you as long as you point them to this site for instructions.
    Tom
