Immobilized
Discussion in 'Prius c Technical Discussion' started by BatScrazy, Jul 2, 2023.
  1. Leadfoot J. McCoalroller
    8,271
    7,775
    Pennsylvania
    2018 Prius c
    Honestly it's the sort of thing you should be able to work out with a visual inspection... and from everything I've read in this thread so far, the whole problem here is that you haven't got the correct RFID capsule in any of the fobs you have for this car.
  2. BatScrazy
    BatScrazy New Member
    16
    Oregon
  3. BatScrazy
    16
    Oregon
    I tend to agree with Leadfoot. When I questioned the service adviser about that he said the technician wanted to replace communication module before proceeding. How do fobs be tested for valid or functional RFID's? There is only one fob for the car, and it had functioned correctly as long as we have had car.
  4. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    Have you checked the fuses? After the dead battery jump, blown fuse can be a typical result. Start by going back to the jump scene and get your friend to explain exactly how he jumped the C.
    Beyond that the only other course of action for you might be to get a 2 day subscription to Techstream for $20 and read up on the immobilizer system for your specific year and model , 2014 C.
    see this wiki page for techstream
    Toyota Service Information and Where To Find It | PriusChat
  5. BatScrazy
    16
    Oregon
    114K miles. Anyone know if I buy a used power management control ECM if it will need to be programmed to car?
  6. BatScrazy
    16
    Oregon
    On another forum someone said the power management unit doesn’t need to pe programmed. I’m trusting in that and ordered a used unit from a Prius C of the same year for $39. Should be here tomorrow. Have the old unit out already.
  7. BatScrazy
    16
    Oregon
    I received the used power management unit. The mounting bracket was bent, put case was fine. Removed mount from original unit and installed on one that came. I installed it in the car, attached the battery leads, and tried the door lock function. Locks worked as the should. Immobilized light was lit on dashboard. I pressed power button and nothing happened. With the original power management unit the display would activate, speedo, warning lights, etc. The immobilized light was still on. I assume that the PM unit may need to be programed?
    I came across a post by Waldox who had a similar problem that was faulty wiring between PM ecu and certification ecu. That will be my next adventure. Can anyone tell me the location of the communication ecu? I'm almost to the end of my interest in this car. Thankfully I'm retired and have other means of transportation. What would its value be in it's current condition, with extra PM ecu? Ha ha.
  8. BatScrazy
    16
    Oregon
    Any ideas of what the car is worth in its present condition? Location Eugene Oregon.
  9. bisco
    52,785
    does it run?
  10. BatScrazy
    16
    Oregon
    It would if the immobilizer would let it. That has been the problem. If you start with my original post it will be explained.
  11. bisco
    52,785
    i have to think a non running 11 year old car with 111k with unknown problems isn't worth much, but if you can find the right buyer who is savvy about these things, they might give you close to kbb unless they think it's going to be an expensive fix.
  12. KenP3_tr73
    KenP3_tr73 New Member
    Rochester, NY
    I have a gen3 Prius that had the immobilizer come on after disconnecting/reconnecting the 12v battery. The AAA driver who was going to tow it for me first told me to sit in the drivers seat with the door closed, then use the fob to lock and then unlock the doors. This cleared the immobilizer fault and the car started right up. No problems since then.
