immobilizer ecu
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Geomiller, Mar 20, 2015.
  1. Geomiller
    Geomiller Junior Member
    Mt. pleasant,pa 15666
    Can anyone tell where the immobilizer ecu is located
  2. Patrick Wong
    18,210
    6,514
    Actually there is no ECU named "immobilizer". However there is an immobilizer system in the Prius.
    The Prius has an transponder key ECU, which perhaps is what you are referring to. If the fob code does not match the codes logged in the ECU then that ECU communicates with the hybrid vehicle ECU and power source control ECU to prevent the car from starting.
    That ECU is located behind the dashboard on the driver's side of the car. Consult techinfo.toyota.com if you need more specific information about how to locate and remove it.
  3. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    You can NOT only change key transponder ecu and key if you lost the key. If that’s what you’re thinking.
  4. Geomiller
    my goal is to replace all the immobilizer ecu's and the only one i can't locate is the transponder key ecu.
    I'm still having no luck locating it . any more specific info on location. I have the entire dash removed .
  5. Geomiller
    Thanks to all i have located it
    Bm Raja likes this.
  6. Bm Raja
    Bm Raja New Member
    sweden
    Hello!
    I am facing same problem. Can you please tel me where the ECU immobilizer located,?
  7. Geomiller
    it can be found passenger side, be hide the heater
    pashko90 and HBS like this.
  8. fresno.prius
    fresno.prius Junior Member
    fresno
    I am also trying to replace my transponder key ECU. Could someone answer two questions relating to this?
    1 Does someone have instructions on getting to the transponder ECU? I can't seem to find the exact location in the service manual and whether to work from the top of the dash down, or the bottom of the dash up, to get to it
    2 Which is better/easier/cheaper: replacing the transponder ECU with a new one ($280) and programming the existing two keys or replacing transponder ECU with a used one ($30) and programming new keys? I haven't tried programming Prius keys before so not sure what is involved. I have Techstream lite but haven't played much with it other than have it open all four doors on one click of remote.
    Thanks!
  9. Figster10
    Figster10 Member
    207
    61
    Sacramento
    Which option ended up being the cheapest or best for you?
  10. TOYORICKY
    TOYORICKY New Member
    2014 Prius c
    Hi I attached a screenshot of the immobilizer, Can you confirm that this is the same one you replaced ?
    I haven't had any luck finding it on the car .
    I only found the red smart key module .
  11. Codysoshelp
    Codysoshelp New Member
    Illinois
    2002 Prius
    Did you find it where is it located and what does it look like? I'm about to loose my mind with this thing
  12. John Ginn
    John Ginn Junior Member
    Mississippi
    What problem did you have that made you decide to change the Immobilzer ECU?
    My Prius had a fuse go out the other day due to the Inverter cooling pump now my car will not sense the key FOB. Toyota tried to reprogram it and it wouldn’t take. I have to insert the FOB into the slot to drive the car. I also have no unlock ability other than the manual key.
  13. mr_guy_mann
    mr_guy_mann Senior Member
    4,104
    2,005
    NJ-USA
    Do you have more than 1 fob? If so then do both have the same problem? Are the fob batteries new?
    I would confirm that the DOME fuse (15 amp) is good (does the dome light work?).
    Then you would need to see what codes are in the smart key ecu ("certification" ecu?).
    The immobilizer refers to the system with the dash slot ("transponder" ecu).
  14. John Ginn
    Mississippi
    I have the red car on dash with the key in it and Toyota nor a locksmith could get the smart key to work or unlock the door s.
    Originally the AC/DC inverter pump smoked and blew the AM2. Fuse.
    I just don’t know what else to check
  15. mr_guy_mann
    4,104
    2,005
    NJ-USA
    Which red car symbol - where on the dash is it?
    I assume that the pump and the fuse were replaced. Have you checked the new fuse to be sure it's good?
    If you put the fob in the dash slot and press the power button once, then twice - what happens exactly? Does the clock come on? How about the MFD (radio - A/C display)?
    If you have a SKS Gen2 Prius, there are 16 ecu's that should respond if you use a capable scantool to check for codes. My next step would be to see what systems respond and what codes are present.
    At the top of the Technical Discussion forum is a sticky thread that reviews several scantool apps and devices.
