Impacts of Running out of Gas
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by asposner, Aug 12, 2005.
  1. SanPR
    SanPR New Member
    31
    Miami Fl
    hey there...
    I ran out of gas approx 6 months ago...
    Car worked fine until about a month ago, when al sorts of lights went on on the dashboard while driving on the highway.
    I was able to drive home, but when I took the car to the dealer, they said that since the car ran out of gas, the battery was discharged and this voided the warranty. I called toyota to see if the dealer was correct, and they said that they stood by what their tech said.
    So....
    Long story short.... There is a DTC that shows up when the car runs out of gas... and if your battery goes bad, the dealer might turn you down and say that running out of gas voided the warranty. It happened to me and toyota backed up the mechanic.
    dont let it run out of gas.
  2. bwilson4web
    16,201
    Details? Speed? Distance covered? Temperature?
    Late, you might have been able to clear the code by disconnecting the 12V battery for 5-10 minutes. I understand this clears old error codes.
    Details like module voltage(s)? Can you get their error codes? Miles on vehicle?
    Are you buying a replacement battery or will you try to fix it yourself?
  3. SanPR
    SanPR New Member
    31
    Miami Fl
    well.. the running out of gas was a while ago... Im in miami, so the temperature wasnt under 70.... I wasnt able to cover a lot of distance, I had to drive up a small ramp to get out of traffic. I had to push the last few feet...
    anyways, yeah, now I know a lot of stuff... but I went to the dealer thinking they were going to cover me... you know...
    I bought a battery off ebay, and the car is working! but now it looks like the 12v went... Im getting the message that the car does not charge in neutral when the car is in Drive.... and I have had to jump the battery 3 times already.
    it wasnt hard... a lot of screws and stuff... but once the orange thing goes, the battery circuit is open and the poles give you 0 Volts.
    I even opened the old battery... it doesnt look like replacing a module is that hard either...
    Car has 80K
    all modules had similar voltages, they were dirty as hell though!! I thnk it was 7.2 V, 15.4V? the Diagnostics from TOyota only gave me one number, (I dont have the papers on me, left them at work) but looking at the open battery it was almost all messed up.
  4. bwilson4web
    16,201
    I bought an NHW20 module, $35, from a salvage via Ebay and tested it with my MRC 989 and it came out at 6.5 Ahr, like new. If you decide to rebuild the original pack, it might make sense to start a new thread in the technical forum. Of course you're 1/3d of the way there if you decide to try and go plug-in.
    I'm curious, what did the replacement battery assembly go for?
  5. SanPR
    SanPR New Member
    31
    Miami Fl
    Oh paid too much!
    I got the pack on Ebay for 1100, there were plenty that were cheaper (one was 650), but this was the only guy that gave me warranty... if it didnt work, he would replace or refund...
    I cracked open the ebay battery too... all terminals were clean... you could tell the difference from mine.... I probably would have had to replace most of my original modules anyways...
    the only thing was that the housing got beat up during travel, so the footprint of the thing changed a little bit and I had to bang it in. If I had the space in the house I would have just replaced all modules on my battery, but hey, I just wanted the thing to run, you know...
    Oh, and Ive never even changed oil... heh what $4000 will do huh...
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Your post started out quite lovely but ended up blaming the car. I really think the only thing you might notice is if there was maybe a really big hammer restrained by a very large MADE IN JAPAN rubber band mounted in the back seat right behind you so when the little blinking gas gauge last bar is activated the glove compartment would pop open...it would then launch a lighted road flare into the back seat..catch the back seat on fire...eventually melt the rubber band..and then the hammer would smash you quite sharply on the back of your head...your head would then be forced quite mightily forward on the steering wheel..forcing you to see through your very bloody eyes that hey...I'm out of gas.
  7. herkeyhawk3
    herkeyhawk3 Junior Member
    2002 Prius
    Asposner, did the red warning light ever go off? Or did you take it to the dealer for a readout?
  8. Dngrsone
    Dngrsone Underwhelmed, to say the least
    189
    Lost in a desert somewhere...
    Guys, the original post was two and a half years ago... the guy who created the thread is probably dead by now.
  9. bwilson4web
    16,201
    I was responding to the recent posting in the thread, not the original poster. It is not uncommon to find even old threads resurrect when someone posts a new piece of information.
  10. Jamez P
    Jamez P Junior Member
    34
    16
    Brownsville Oregon
    Can confirm this. I got 90 miles after the bar started to flash. Did this on purpose (with gas and OBD scannner JIC) in order to get that valuable bit of info.
