Impressive highway fuel economy
Discussion in 'Gen 4 Prius Main Forum' started by jtg61, Feb 28, 2017.
  1. jtg61
    jtg61 Member
    46
    43
    Ocala FL
    I just made a trip from Hollywood FL to Ocala FL on the Florida Turnpike which was 284 miles. I managed to hit 70.5 MPG on the tripometer. I'm sure this isn't a record in this forum but I was pretty impressed in my 2016 Two Eco. At four gallons of gas, I paid more tolls on my SunPass. WP_20170228_002.jpg
    djasonw, Priifan, goldfinger and 9 others like this.
  2. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    What speed were you traveling at? Also was it moderate to heavy traffic? That is very good mileage on the interstate.
    jtg61 likes this.
  3. jtg61
    jtg61 Member
    46
    43
    Ocala FL
    I was averaging 65mph on the Turnpike between 9am and 2pm on a Tuesday afternoon in light traffic.
    robsnyder20 likes this.
  4. MichelleStone
    MichelleStone Senior Member
    549
    819
    Mariposa, CA
    I have found that if I'm not in stop and go traffic, it's a moderately warm day, keep the cruise control on, and keep it under 68, I get great mileage. My mileage has gone down about 5 MPG with cooler temperature. Mind you, it's not "cold" here. It's usually in the low fifties.
    jtg61 likes this.
  5. robsnyder20
    378
    302
    SW Florida USA
    I have done some smaller runs in florida ~10 miles with warmer weather but mine was no where near as good as OP's. This was taken in the Wee hours of the AM, no drafting, no lights or stops. Reset trip computer after about 7 miles warm up between two cities on my commute home. One note this is with climate control set at auto AC ~ 70 degrees and mine is not an ECO, but using ECO mode IMG_20161101_031332.jpg
    jtg61 and RCO like this.
  6. eman08
    eman08 Active Member
    360
    192
    US
    Mendel Leisk, RCO and jtg61 like this.
  7. PriusFan06
    PriusFan06 Member
    60
    33
    SF Bay Area
    Just picked up my 2016 Prius two and I feel my average mpg is not as great as others.
    Right now I got about 6,200 miles on it. Avg temp here in San Jose, CA is about 65 degrees.
    I get on freeway on avg 61.5mpg. I drive with Normal mode. Tried Eco mode and it was pretty much the same. i hear many of you guys getting sub to high 60s. I checked my tire psi and I made sure the psi is 1 above what is recommended on sideslip of the car.
  8. Prodigyplace
    12,720
    11,852
    Central Virginia
    I found it interesting that at the Prius mileage challenge yesterday they set tire pressure at 45.
    I set mine to the higher pressures used by the Eco. Front 39 Rear 36.
    jtg61 likes this.
  9. PriusFan06
    PriusFan06 Member
    60
    33
    SF Bay Area
    45psi seems a bit high IMO. I set my fronts at 39 and 38 rear. I have noticed a bit difference in MPG vs. the recommended psi.
    jtg61 likes this.
  10. Prodigyplace
    12,720
    11,852
    Central Virginia
    Max pressure on my tires is 44
    jtg61 likes this.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    It's how you drive the car as much as the tyre pressure that affects your mileage, but yours is a good ball park figure IMHO. The high sixties are probably from experienced Prius hypermilers, slow speed, gentle acceleration and braking. Yours will get better as the warmer weather comes back again.
  12. jtg61
    jtg61 Member
    46
    43
    Ocala FL
    Mine are also set at the Two Eco recommended pressures, 39 front, 36 rear.
    Prodigyplace likes this.
  13. Tideland Prius
    16,683
    You know you're a Prius owner when 61.5mpg on the highway is not high enough :ROFLMAO:.
    Welcome to the club!
    farmecologist, Priifan, jtg61 and 5 others like this.
  14. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    I love going somewhere and complaining at how the traffic lights were all messed up and I only got 70 mpg instead of 101 in the PiP. They throw such a pity party for me! :ROFLMAO:
  15. PriusFan06
    PriusFan06 Member
    60
    33
    SF Bay Area
    LOL...my wife thinks I'm crazy for trying to reach mid to high 60s MPG. And yes, I do live in an area like the autobahn. The SF Bay Area drivers love to go on average 70-75mph. I try to drive 65 to 70 constant yet I still get honked at and get cut off.
    Priifan, tucatz and jtg61 like this.
  16. IAPrius
    IAPrius Active Member
    120
    140
    West Des Moines, IA
    If I set the Prius at cruise at 75 mph I get about 48 mpg in the winter and 53 mpg in the summer. I have 14,500 miles since July and I averaged 50.2 mpg of mostly highway driving.
  17. Priifan
    Priifan Member
    93
    143
    Cary, NC
    These numbers make me smile! Having driven a Prius for four years, it still is difficult remembering that the car DOES use gas, and that that tank does have to be filled every now and then. Working out of a home office, I drive so few miles that it can take a month to empty the tank. Toyota, thanks for making this a problem! (And I bought my 2013V Three and 2017 Four because they are fun to drive...not because of the gas savings.)
  18. Prius Pete
    Prius Pete Active Member
    183
    178
    Toronto
    I find with my Gen 2 that the wind direction makes a significant difference to the highway gas mileage. I always check flags along the way to see if I have a headwind or a tailwind.
    djasonw likes this.
  19. jerrymildred
    11,517
    14,171
    Tampa, FL
    I do that, too. Makes a huge difference. And I suspect that cross winds are worse than headwinds.
  20. fuzzy1
    10,723
    You suspect correctly.
    The Prius is optimized for direct head-on wind. Or, highway speed into calm air. When I joined here 8 years ago, one of the threads had a graph of drag vs. wind direction. Front-quarter winds were worse than head-on.
    William Redoubt, RCO and Mendel Leisk like this.
