Improve A/C cooling in 04 Prius.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PepoGimez, Jun 25, 2016.
  1. PepoGimez
    PepoGimez Junior Member
    46
    Phoenix, AZ
    I live in Arizona, so good A/C in my car is something I appreciate, a lot. I bought my 04 (maybe 05) prius around two years ago. This is the third summer i've had my car.
    At first the A/C was really nice. The air would be very strong on max and would cool quickly. Now while completely acceptable, takes longer to cool. The air doesn't seem to come out as strong as it did before either.
    My main question is, is there any reason I would need to "Recharge" my A/C system after this time?
    I've had my car serviced at Toyota dealers since I got it but i'm starting to try to learn to service simple things on my own to save a bit. No A/C problems, although they always recommend I get an A/C cleaning every time I get it serviced.
    If I do need to add some of that special oil/gas coolant, how do I know when I have enough? (I have a new A/C coolant can with a gauge for my other non-hybrid car, but I don't know how to use it exactly).
    Thank you!
    EDIT: I understand there are a lot of posts about this general topic, but they all seem to include some info about their A/C system leaking. Which I don't think is the case here as it still cools well. It just takes about twice as long as before to get there.
    52,662
    if the air doesn't come out as hard, you should check the fan and filter.
  3. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    Dude... it's been >110°F EVERY DAY! You can't expect it to blow frost at you.
    Replace your cabin filter just because it probably needs it.
    ALWAYS run A/C in recirculate mode to allow it to cool optimally.
    To check your A/C system w/o tools:
    Turn car on. Set A/C to full blast, windows open, fresh air intake.
    Open hood. Find sight glass at high pressure connection on left (circled in red). Wipe it off. If you see bubbles, you need to add R-134a obtained from wal-mart or a parts store. I recommend wal-mart... about $4.88/can last time I bought it a couple weeks ago. MAKE SURE IT IS STRAIGHT 134a. NO OIL. NO O-RING SEAL. NO DYE. JUST PLAIN R-134a. PERIOD. UNDER NO CIRCUMSTANCES ARE YOU TO USE SOME KIT OR OTHER SUCH ITEM THAT CLAIMS TO IMPROVE YOUR A/C. Those kids contain PAG oil that will potentially damage your expensive compressor.
    The low side is indicated by the blue arrow. You have to look down in there. You'll either see a gray cap that says "L" or what looks like an oversized tire valve. That's the low side. You only put it in there.
    You'll need a hose and can tap. Again, readily available from Walmart or an auto parts store.
    All three of my Prius' needed about half a can this summer... 03, 07 and 08 models.
    If that doesn't get you where you want to go, the only thing you can do without replacing parts is to get a full system evacuation and recharge. Either go to a Toyota Dealer, or go to a shop that knows Prius systems inside and out. The equipment shouldn't even be used on non-hybrd cars to prevent contamination of the system with non-hybrid oil.
  4. Patrick Wong
    18,210
    6,516
    1. Check the cabin air filter and replace if necessary.
    2. The refrigerant level may be slightly low due to a minor leak, which results in less efficient AC operation.
    3. Do not add refrigerant oil since the special ND-11 oil is required. There is no need to add oil unless you have a major leak or are replacing the air conditioner compressor.
    4. If it is necessary to add R-134a refrigerant, make sure that the can only contains refrigerant (and not oil or leak sealant). Use a low pressure gauge and observe the spec which is 29 psi. Do not overfill as generic instructions would have you do.
  5. S Keith
    799
    329
    AZ
    2003 Prius
    Patrick, I have immense respect for you and your Prius knowledge; however, this is not sound advice. It contradicts the repair manual procedure, which is as I describe above (in part). R-134a high/low side pressures are completely dependent on ambient air. 29psi low side would only be appropriate if ambient air temperatures were 65°F.
    The sight glass method ensures proper refrigerant phase regardless of ambient conditions.
    Under no circumstances should you use this on your Prius.
    Steve
    #5 S Keith, Jun 25, 2016
  6. PepoGimez
    46
    Phoenix, AZ
    I have changed both filters recently. I'll look up how to check the fan. Thank you!
  7. Patrick Wong
    18,210
    6,516
    The spec assumes the following conditions:
    Temperature at air inlet 86 to 95 degrees F, recirculation on.
    Blower speed high.
    Temperature MAX COLD.
    AC switch on.
    Fully open doors.
    The last four conditions are normal procedure when recharging refrigerant in a typical vehicle.
  8. PepoGimez
    46
    Phoenix, AZ
    You're right, but I never said I wanted frost. I would just like the A/C to work as it has the past two summers. I understand it has it's limitations, but I feel like it isn't performing quite like it should.
    I have recently replaced both filters in my car.
    Ok, I'll definitely keep that in mind.
    Oh ok, i'll go ahead and check that. I understand the chemical is different but I thought since it was an unused bottle maybe the gauge was still viable, but since my system still works i'd rather spend a bit on a new gauge when I get the 134a, if I need it of course. Thank you for your reply.
  9. PepoGimez
    46
    Phoenix, AZ
    Ok! Thank you very much for the advice, i'll keep it in mind when checking. So the gauge should reach 29 psi when filling?
  10. PepoGimez
    46
    Phoenix, AZ
    So I should eye ball it with the sight glass method rather than using a gauge?
    Thank you, and no worries I understand that that chemical is no good for this. I just thought I could use the gauge since the seal is still intact. But i'll spend a bit more to make sure I don't break my system since it's still running fine (just could run better).
  11. PepoGimez
    46
    Phoenix, AZ
    When I do this, it'll be either early in the morning or later in the afternoon when the temperature goes down a bit. However, most of the day it's around 110 degrees or more and my car is parked outside. I don't know if that makes a difference.
  12. S Keith
    799
    329
    AZ
    2003 Prius
    I agree completely; however, the 29psi low side pressure for R-134a is completely off the mark. Low and high side pressures for R-134a CHANGE with ambient temperature.
    The first thing they say to check is the site glass. If bubbles, "add refrigerant until bubbles disappear".
    The range Toyota gives is not accurate according to their own sight-glass criteria and way off the mark per most other. While 29 psi is the average of the listed 22-36psi, it is misleading to establish this as a limit. It also doesn't account for a compressor that may not be operating at max efficiency due to age or other wear factors.
    I can tell you from experience that in almost every case, you will be at or a little above the upper limits for the low side pressure at the prescribed ambient temperature when you add sufficient R-134a to get rid of the bubbles.
    Are you basing this on data or "feel?" You're complaining about your A/C on the hottest weather we've had in the last few years... :)
    You're also aging. You might be putting on weight - all subjective things that could influence it.
    Point is that without actual data, you can't really say that it's working any differently than the last two summers, particularly when the last two summers were a little cooler than this one.
    Best to "keep 'em separated" to drive it home that they should never be interchanged.
    No. Sight glass per the manual. You will probably go over 29 psi.
    Or the two together. Site glass first. Confirm with pressure. STOP when the bubbles stop.
    Early morning/late evening is what it's going to take to get to the 86-95°F range.
    Car parked in the sun makes a huge difference. I personally use sun shades and crack all my windows at least half an inch to try and keep interior temps as low as possible. If they're elevated, I'll drive my first 1/4 mile with the windows down about halfway to flush out the searing hot air in the car with the cooler outside air.
  13. PepoGimez
    46
    Phoenix, AZ
    Thank you for the effort on this reply.
    Yeah it's definitely going on feel. But I'm quite confident that it's taking longer to cool. But since it is "feel" I could be dead wrong. I just want to figure out how to check if this "feel" has any merit. Which seems like the sight glass method should do.
  14. S Keith
    799
    329
    AZ
    2003 Prius
    When it's 110-118°F (or higher), it's not going to cool off in a 20 minute drive. Yes, it will blow cool, but it's going to be on near full blast the whole time even on recirc. The interior will never get uniformly cool where the A/C will turn itself down unless you have the temp set to > 80°F. I leave mine on 78, and it NEVER catches up to the set point on my 25-30 minutes drive home.
    It's effin' hot out there, dude...
  15. ChapmanF
    18,861
    Hey guys,
    I've run out my techinfo days for the time being, so I don't have the Gen 2 manual in front of me. But I remember that the Gen 1 A/C was a subcooling condenser design, which meant the proper charge was not right when the bubbles stopped, but so-many-additional-grams-of-refrigerant (100g if I remember right) after the point where the bubbles stop ... which of course involves having a decent scale to rest the refrigerant can on.
    Gen 2 is still a subcooling design, is it not? If you've got the manual handy, does it not still say a certain additional weight of refrigerant after the bubbles stop?
    If you just stop when the bubbles do, you'll have put in the proper charge for an oldfangled A/C system without subcooling, but it'll be a bit undercharged for the Prius.
    But all of that also depends on the exact ambient temperature range and operating conditions (doors open, etc.) specified in the manual ... if you do it when it's really effin' hot out, you'll probably never see the bubbles totally stop, or you'll overcharge the system trying to make them stop.
    -Chap
  16. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    one other thing is to make sure your condenser isn't packed full of dirt and bugs. if it looks dirty, you can blow it from the inside out with compressed air. I have used wheel cleaner on my home condenser when it was clogged, I don't know if that would work on a car though.
  17. Mendel Leisk
    42,153
    Maybe check out the dealership's charge for an AC service?
  18. S Keith
    799
    329
    AZ
    2003 Prius
    Yep. Bubbles stop + 100g (75 - 125g), but it's phrased as "may need to be charged after bubbles disappear"
    (Total Qty: 450 +-30 g (15.9 +-1.1 oz.) )
    For simplicity's sake, I have found the bubble-stop method to be sufficient on all 3 of my cars in Phoenix weather, but I like your idea of a scale. I have a 0-500g scale that would more than suffice. I'll try that next time.
    We've discussed the need to do it at lower ambient temperatures (86-95°F per the manual) above.
  19. Patrick Wong
    18,210
    6,516
    Many opinions expressed here.
    The first question is whether the OP's AC system needs help. If he thinks the cooling quality has diminished, it probably has. However that is up to him to determine.
    In an effort to be somewhat scientific, I will provide one data point from my 2004, taken at 5:15 PM Mountain Standard Time this afternoon (AZ does not observe DST). The AC system on that car has remained untouched since the car was built in 2003.
    The sight glass shows no bubbles. The ambient air temp is 100 degrees F according to the Prius temperature gauge. The car had been driven slightly more than 15 minutes after being parked outside at a local movie theater, returning home. The car is set to Auto AC with the cabin temp set at 78 degrees F. You can see that the air coming out of the center left vent is below freezing temperature. That is how it should be.
    Steve correctly cited the spec for refrigerant amount is 15.9 ounces. Since one can of R-134a contains 12 ounces, it is possible to overcharge the system without trying hard. Hence my suggestion that the OP observe the low side pressure when recharging.
    However, even if he overcharges the system, if it works better than before that is goodness, and assuming the system has a small leak then the excess charge will leak out as time passes...
    Here is a link to the Walmart product that I have bought recently (for my daughter's 2007):
    Speed Steed R-134a Auto Air Conditioning Refrigerant, 12 oz - Walmart.com
    P6260044.JPG P6260041.JPG P6260040.JPG P6260039.JPG That car has a very small leak in the AC system which is not obvious after using a dye, so it probably is in the evaporator area. The leak is tiny so I haven't bothered to take apart the dashboard to get to that area yet.
    mmmodem likes this.
  20. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Just wow! (y) 220k miles with AC that still works over 10 years old and gets 48 mpg to boot. Kudos to a well maintained vehicle.
