Improving Fuel Economy AND Performance together on 2004 Toyota Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ZFL, Mar 19, 2011.
  1. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    I may have been unclear, I programmed x-gauges into the Scangauge, not into the car's computers. The X-gauges allow you to see model specific values that are not standard in every car. The Prius has many values unique to that car, X- gauges allow you to see them, you can spy on what the computers are discussing amoung themselves.
    http://priuschat.com/forums/gen-ii-...uge-how-area-please-share-your-knowledge.html
    Passive x-Gauges only snoop, active x-gauges prompt the computers to generate a value they would not normally show. There is slightly more risk with an active x-gauge. Some folks can change the back up beep settings with an active x-gauge.
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I know of nobody here who has converted a Prius to run on CNG. I used to think Pickens plan was a good idea since it seemed like it wasn't that much effort for an automaker to converter a gasoline powered car to run on CNG. After reading a bunch of stuff I ended up posting at http://priuschat.com/forums/other-c...atural-gas-vehicles-were-so-slow-fill-up.html, I'm not so sure anymore.
    I'm getting kind of confused by your posts (but haven't read this thread that carefully). You seem to only be able to afford an 04 Prius and can't even afford an 06 (not that an 06 will yield better mileage) but yet you seem to want to dump a bunch of money into dubious mods or going into uncharted territory. I'd say, don't bother for now. Get the car, block your grille until it's too warm to do so, get a ScanGauge and EBH.
    Once you get used to the car, then study up and practice some of the mileage improvement techniques and adopting some of http://www.cleanmpg.com/cmps_index.php?page=hypermiling that you're comfortable with (and that can be done on a Prius). Some are totally safe, free and easy like parking face-out.
    You can consider some handling mods, but they definitely won't improve your mileage.
    There are many running lists of XGauge values but it seems the one at https://spreadsheets.google.com/ccc?key=0AiHL0r_2nhUEdF9lVVBxOVNoN3Zva3E0NmdZTUR1eVE&hl=en#gid=5 is the most complete (under the Prius Gen II XGauges tab).
    Other useful aspects of the SG are that it's basically required if you want to try to drive in "Super Highway Mode" (see links at http://priuschat.com/forums/gen-ii-...angauge-best-threads-mileage-improvement.html). You need to maintain IGN 13-15, and you'd need a tool like SG to see IGN (ignition timing values). Also, being able to see coolant temperature (FWT on SG), and better manage your heater use (and thus improve your mileage), when the ICE is cold. If you want to read about the gory details (might seem abstract), see http://priuschat.com/forums/newbie-forum/91431-one-3.html#post1287385.
    Since you asked "on a scale of 1-10, how much does the scanguage help you be a better driver?" Hmm... that's a tough one. It gives me insight into a some things that are going on and made me realize that some of my assumptions were wrong. It's somewhere between a 4 and 7 for me, it's just so hard to say and really depends on whether you can take advantage of techniques safely.
    For instance, I found SHM unsuitable for my commute in CA (http://priuschat.com/forums/gen-ii-...y-mode-alternative-65-75-mph-range-hints.html). I now do a lot of short city drives, so it's totally N/A now. When I'm on the highway in WA, the speeds and speed limits are lower, so I'm in a more suitable speed range. But, there's usually too much traffic around me to be able to safely focus on maintaining the proper IGN value. It takes quite a bit of concentration for me.
    BTW, you may as well set a price alert at Amazon price tracker, Amazon price history charts, price watches, and price drop alerts. | camelcamelcamel.com for ScanGauge.
  3. ZFL
    ZFL Junior Member
    47
    East Metro Atlanta, Georgia
    Okay I understand now
    Sorry, I should have been more clear. My parents will pay for the car and those were only ideas and the few mods I use ( very few) will be bought from my monthly earnings. I will stick to the simple things based on the advice I have been given. Thanks. Also, what is EBH?
    Also, I have one more question. what is the risk of active Xgauge that you mentioned?
  4. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    EBH == Engine Block Heater
    It's debatable but if you use any active (solicited aka non-passive) codes, I suppose you run the risk of throwing a code. See http://priuschat.com/forums/gen-ii-...olicited-gauges-hot-pugging-warnings-etc.html and http://priuschat.com/forums/gen-ii-...iately-got-these-error-codes.html#post1287119.
    I definitely do have some solicited XGauges programmed into mine...
  5. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    If you don't have short commutes all the time and you're into learning hypermiling, you could top 50 mpg easily, especially since you have a warmer climate down in sweet old Georgia. I have some terribly annoying hills and cold-ish weather to deal with and still seem to be able to keep that as the mileage floor in the worst of conditions. You'll also get better at driving it from any test drive. In my few months of ownership I've been able to get 15-30% better on more recent tanks compared to first ones, in similar temperatures. My "mods" have cost me a few dollars, literally - around 40 psi and stuffed some pipe insulation into my grill.
    I get where you're coming from, trying to have fun with the car...I think though you'll find plenty o' satisfaction and fun from the ever-evolving game of driving it more efficiently.
  6. richard schumacher
    7,664
    1,045
    United States
    All those products are useless in a Prius. Nothing can be done to a Prius to increase MPGs, and increased-power mods blow the emissions to hell. If you want a project car get a used Honda.
  7. ZFL
    ZFL Junior Member
    47
    Hey all!
    Not sure who will see this since it's a dead thread, sorry about that. I want to thank everyone here who gave me such sound advice. It was especially helpful considering I was at the brink of childish insanity back then haha it's incredible.
    Just a update: I bought an '07 Prius not too long after! It had 214,000 overwhelming, smelly and strong miles. Being 3\4 past 22 yrs young and now it has 232K miles on my watch and I'm proud to own one (minus any ridiculous mods). I'm in love with it and know now to keep any changes sensible.
    I appreciate it!
  8. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Did you make your 55 mpg goal?
  9. ZFL
    ZFL Junior Member
    47
    Good question. From what I remember, heck no, but I got nearly 50 mpg with an overall weak battery :cool:. It's the original one I think, since it decided to give up on me early last year :eek:
    I would usually just inflate the tires a little extra, feather the throttle, keep the cargo small and of course, pretend the brakes don't exist. Occasionally, I was a speed demon and would fly past other cars so my low would be 44-46 mpg
    #49 ZFL, Jan 27, 2016
    mmmodem likes this.
  10. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    Interesting read--and resurrection!
    I find that you can do some pretty spirited driving and get good fuel economy by focusing on maintaining momentum once you have it. I've been experimenting with pretty spirited acceleration, racing lines around the corners where possible (fun and helps preserve momentum) combined with efficient steady-state cruising/coasting and minimal braking. The lowest tank has been 51 mpg (cold temps and snowy roads) but it's usually in the high-50s and sometimes over 60 mpg in warmer weather (grippy, non-LRR tires at 35psi r/38psi front).
    I'm glad you've changed your mind on the modifications. I've found a few that helped on the old 4wd, but the vast majority of mods are just big $$$ and disappointment.
    ZFL likes this.
  11. mmmodem
    2,732
    1,703
    Bay Area, CA
    I had a stock 2006 Civic EPA rated at 36 mpg highway and I could average 40 mpg easy keeping up with traffic in the left lane going 75-90 mph. If I moved to the right lane and hung out with big rigs, I got 45 mpg. The only hypermiling technique I followed was Driving Without Brakes (DWB). The long following distance pisses off left lane drivers so I often stayed out of the left lane.
    I researched grill blocking, pizza pie hubcaps, etc. But what I found was "enhancing my calm" is the biggest bang for your buck in terms of fuel economy. The more relaxed I am the more sedately I drive. The more anxious and stressed I am, the faster I drive.
    How do you relax yourself?
    1. Give yourself plenty of time. I arrive at work or whatever destination at least 15 minutes before I need to. If there is extra traffic, no biggie.
    2. $15 Audible membership. Harry Potter on audio book saved me a lot of money. Alternatively listen to podcasts for free. Sometimes I wished there was more traffic or drove slower so I could hear the ending.
    ZFL likes this.
  12. ZFL
    ZFL Junior Member
    47
    Thanks! You hit the nail on the head. My FE flies when I'm calm, maybe listening to NPR (duh), but AC/DC doesn't help at all when I'm in the car. I've considered listening to TED Talks as well. All these things do well and I'll use them, but eventually I will begin investing in lighter weight wheels, lightly improved aerodynamics, and other little methods of improving efficiency. They will pay themselves off because I plan to keep the car for life.
    mmmodem likes this.
  13. bisco
    51,784
    please don't mention npr here, it just perpetuates the myth.:cool:
    #53 bisco, Mar 14, 2016
    ZFL likes this.
  14. ZFL
    ZFL Junior Member
    47
    :D That's so funny. I suppose I partly support the myth of NOR. How about PVS? I wonder if I slap both of these on my car my mpg will go up while my performance goes down...:giggle::whistle:
  15. bisco
    51,784
    spell check must have been written by a conservative.:cool:
  16. ZFL
    ZFL Junior Member
    47
    Lol alright let's just leave this on a high note. :D On to the newbie thread to post pics....! (y)
  17. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Just food for thought. My last road trip in my 2008 with stock 16s and with the full exhaust mods I was able to have a trip average of 50.48mpg...doing +65mph
    The exhaust seems to have given my butt-dyno-meter a bit of a boost in performance at higher rpms.
