In-dash Navigation for Right Hand Drive Prius
Discussion in 'Gen 3 Prius Audio and Electronics' started by MSKamarudin, Feb 28, 2011.
  1. wongabraham
    wongabraham New Member
    malaysia
    there a acc shop in klang have the oem fit headunit
  2. kchia1
    kchia1 New Member
    malaysia
    do you happen to have the shop name & address.
  3. wongabraham
    malaysia
    2a,Ground Floor,Jalan Sentosa 5,Taman Bayu Tinggi,41200,Klang,Selangor. gps coordinates:N 03.01338 E101.43148 TEL:03 3326 3708
    but the shop say it is a demo set cost 2.5k plus
  4. kchia1
    kchia1 New Member
    malaysia
    Thank you, Wong... :)
  5. wongabraham
    malaysia
    no problem man
  6. kchia1
    kchia1 New Member
    malaysia
    Hi Wong,
    I've a couple of questions, do you know any 2010/2011 Prius accessory shop in KL? Such as selling the Custom Sun Shades, Window Visors, & etc?
    Appreciate for your respond. :)
  7. MSKamarudin
    MSKamarudin New Member
    Malaysia
    How's the audio and video quality? I am happy with the current OEM sound quality and would not tolerate with something inferior to that. What is the make?
  8. wongabraham
    malaysia
    still ok la
  9. MSKamarudin
    Malaysia
    What do you mean by OK? As good or so so. How's the installation? I hope no "potong" (wire cutting) involved.
  10. MSKamarudin
    Malaysia
    Dear Jeremy, could you post photo of 2 Din Unit installed in your Prius? Curious to see whether it blends well or better in the car that the OEM unit. I have yet to check out the unit mentioned by Abraham here and therefore have not decided whether to fit a 2 Din Unit or OEM look alike unit.
  11. Jeremy Harris
    Jeremy Harris New Member
    221
    39
    Salisbury UK
    I've just taken a photo of the old Kenwood DNX5220 that I currently have fitted for you. The fascia panel is the Toyota part and fits well, but as you can see it needs two spacers (available from Metra) to convert the slightly wider opening to a true 2 DIN size.
    Hope this helps.
    Jeremy
  12. MSKamarudin
    Malaysia
    Any idea what is the brand? In their FB, they stated that the RHD Caska for Prius is still being developed.
  13. wongabraham
    malaysia
    No potong is involve they use oem fit plug and btw I change all my speaker to vifa and add a amp and soundproof my whole car the quality is superb
  14. wongabraham
    malaysia
    No brand yet. And my friend said he os looking in china I will keep on post
  15. johalareewi
    johalareewi Member
    393
    44
    uk
    Flyaudio.eu are still looking into producing an EU version for the right hand drive Prius but want to find out what the demand is likely to be.
    If you are interested, you can tell Flyaudio at flyaudio.co or flyaudio.eu
    If you are interested in RHD Flyaudio unit in Malaysia or Thailand and so on, perhaps you can still let flyaudio.eu know (and maybe your local flyaudio dealer).
  16. Jeremy Harris
    221
    39
    Salisbury UK
    Just for info, there has been a right hand drive version of a unit very similar to the FlyAudio one available for a while now. I bought one a few weeks ago and it's OK. See this post for details: http://priuschat.com/forums/gen-iii...4772-factory-look-gps-ebay-4.html#post1349476
    Jeremy
  17. johalareewi
    johalareewi Member
    393
    44
    uk
  18. MSKamarudin
    Malaysia
    Thanks Jeremy.
  19. Tho Chee Kin
    Tho Chee Kin Junior Member
    Shah Alam Malaysia
    Jeremy, checked on Metra site, they only have left hand drive now. Can you share where you got it from (if e-purchase)
  20. Jeremy Harris
    221
    39
    Salisbury UK
    The Metra infill kit will fit both LHD and RHD, as it just fills in the gaps either side of the Toyota OEM dash panel. The Toyota panel is designed to take their own aftermarket nav system and has a 200mm x 100mm opening, which is 20mm wider than the standard 2 DIN size of 180mm x 100mm, which is why the Metra infill pieces are needed.
    The part number for the Toyota OEM panel is 55405-47070 and it is available from Toyota dealers. Full info is on another post in this thread, here: http://priuschat.com/forums/gen-iii...ation-right-hand-drive-prius.html#post1274986
