In-dash USB charging ports
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mgb4tim, Mar 27, 2017.
Tags:
  1. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    After nearly 8 years of ownership, my 2010 finally has in-dash USB charging ports.
    It's clean, a perfect fit, and cheap - from Amazon.
  2. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    Looks good! Unfortunately that spot has been taken as my car has OEM heated seats. I'll stick to the one that is in the cubby and a USB charger in the cubby.
  3. ChapmanF
    18,993
    Maybe replace that plastic panel with the same one for a PiP? I think the PiP could have seats with two heat levels, using one of those rectangular switches for each seat. You could put your combined seat switch in one, and the USB gizmo in the other.
    -Chap
    WolfpackBill likes this.
  4. Shaun_Collins
    Shaun_Collins Junior Member
    48
    Tulsa / Broken Arrow / Catoosa Area
    Anyone done this to a Gen 2?
    LG-H918 ?
  5. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    In what cubby? There's a couple other places the same plug would fit perfectly. This just worked out well for me. I don't have USB in the armrest, just the AUX input. I have an earlier 2010 that I bought in July 2009, pre-USB input.
  6. WolfpackBill
    349
    500
    Lexington, NC
    The center console. I have JBL navigation so the oem USB port is right next to the aux port and a 12V power port next to it so I plug in a USB charger for other phones for passengers.
  7. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    My early JBL w/Nav doesn't have a USB. They rolled that in later in the model year. I used to keep a charger in that 12v port, but didn't like the cord coming out of that arm rest.
  8. MarvinHC
    MarvinHC Junior Member
    49
    Europe
    where did you connect it under the plastic? Would you have any pictures? Thanks so much!
  9. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I made pigtails form the 12v outlet. Was pretty simple to do on the workbench. I'll see if i can pull it out and take some photos in the next couple days.
  10. MarvinHC
    49
    Europe
    Thanks for your reply. I'll have a look in there over the weekend, was just curious if you used the 12v outlet (which of course makes most sense) or connected elsewhere.
    Would you also be able to tell me where the clips are / how to best remove that plastic surrounding the 12V outlet? Thanks so much.
    #10 MarvinHC, Feb 22, 2018
  11. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I think I just pried the bottom of the panel. You can see where I scratched it in the original photo I posted, so be careful.
  12. Xterra72
    Xterra72 Senior Member
    1,437
    1,684
    Here’s my setup.
    Low profile usb chargers, lightning cables and micro usb cables. 4 total connections.
    Works great! No more issues with someone not being able to get a charge, especially for people sitting in the back.
    m3pare and RMB like this.
