In EV mode, ICE still runs after stop
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by michaelmross, Oct 4, 2013.
  1. michaelmross
    michaelmross New Member
    I'm convinced this is a real problem with my 3-month-old 2013. When I bring it in for the 5K service, soon, this will be my No.1 issue. When running in EV mode, if you happen to start the ICE it will continue to run when you stop. In fact, it races - it doesn't just idle. I've tested this by being stationery for up to 5 minutes. This occurs not just the first time the ICE cycles on and off - it's every time. It only stops while driving (or by powering off).
    Anyone else?
  2. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    The ICE has to complete it's warm-up cycle once it's been started up, so yes it can be running even if the car is stationary. It's happened to all of us PIP owners.
    The only way to interrupt the ICE warm-up cycle once it's started is to turn the ignition off.
    If you put the car in "eco mode" the ICE will run for a shorter amount of time in the warm-up cycle IIRC.
    CaliforniaBear likes this.
  3. michaelmross
    That's probably what they'll tell me at the dealer, but I think it's screwy. Your MPG after a short ride is either 999 or 69! - is that the way it has to be? If you press the gas too hard for 10 seconds, I don't understand why the ICE has to stay on for 5 minutes - stupid behavior when you're doing a 4-mile trip.
  4. markabele
    5,084
    1,782
    Nebraska
    Do you live on the pit area of the Indy 500? Why are you needing so much acceleration?
    chesleyn and Priusmpg like this.
  5. SJ PiP
    SJ PiP Member
    190
    35
    ICE will also kick in when engine is cold, EV battery is already full and you have a steep descent (to protect from overcharging battery). at least this one can be avoided by running AC on full blast to "bleed" some EV (kind of silly since it's usually chilly outside first thing in AM)
  6. bisco
    52,880
    if you're saying that the ice will stop after warm up while you're driving, but not when you come to a stop, or runs at all after full warm up, then something is wrong. read the faq about the ice starting, then come back with questions. but yes, if you accellerate into the power zone with cold ice, it will come on and complete the warm up process for emission reasons. you can avoid this by not accellerating into the power zone. you are not the only one with this complaint, some have switched to volt for this reason.
    F8L likes this.
  7. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    many people dont have the correct DISPLAY screen showing, to maximize their efficiency. Use the HSI screen and watch the power bar, as you accelerate. You can power on all the way across until the RED Power section at exteme right side. That is when the ICE starts.
    It should never run 5 minutes, mine even in mid winter does not run that long, maybe 3 max.
    always keep MODE in ECO, as the pedal becomes "longer" and less "connected" to your foot. If you run POWER mode its much easier to inadvertently fire the ICE since the pedal becomes "shorter".
    Anytime you hear motor "race" is when its in warm up mode, which is typically fairly quick.
    If you are describing your symptoms accurately you may have an issue where ICE is not warming up quick enough. But Im guessing there is nothing wrong and just need to drive it like a prius, not a normal car...lol
    I drive mine much more briskly once ICE is on and EV is gone....but when in EV drive like there is an EGG under your pedal.
    Dan
  8. Bill Collins
    Bill Collins Junior Member
    East rutherford N.J.
    2013 Prius Plug-in
    if ya have a heavy foot and like jack rabbit starts don't buy a PIP
    chesleyn, F8L and markabele like this.
  9. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    I beg to differ. I experimented with that very premise in mine just last night to get some real-world data. Now that temperatures are dropping (it was 46°F then), I specifically wanted to find out what a drive normally all-electric would result in with engine warm-up.
    It was just a 3.0 mile drive. The maximum speed was 45 mph. There were several stoplights. About halfway into the one-way trip, I dropped the pedal hard to fire up the cold engine. Coolant temperature reached 130°F about a block before reaching my house, automatically shutting the engine off. The result from that drive which could have been 999 MPG ended up being 101 MPG.
    No regular Prius can even remotely deliver the same efficiency. So what if the engine started. During the first minute of warm-up, the plug-supplied electricity is used to keep RPM under 1500. It makes quite a difference.
  10. bisco
    52,880
    but the ice should still shut down after warm up when you come to a stop.
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I think you missed his point. If you like to race around from stoplight to stop light and don't want the ICE to fire up then don't buy a PIP. He said nothing about comparing efficiency between Prii models.
    markabele likes this.
  12. Emcguy
    Emcguy Member
    177
    29
    Australia
    It sounds like an amplified version of my problem. My wife drives the kids to school 1.5km gets out and chats to her friends 30min. Then drives home. This is repeated after school. There is a steep 50m run outside our house so unfortunately the engine is always on :-$
  13. Emcguy
    Emcguy Member
    177
    29
    Australia
  14. john1701a
    12,840
    5,312
    58
    That point applies to all models of Prius... and the broader sense, any hybrid. Racing around is inefficient. It wastes fuel. Would you really want to sacrifice EV range instead?
    The engine will run from time to time. That's why there is one. If everything is off, including the heater, it's a simple matter of measuring how long it takes for the engine to shut off when the vehicle isn't in motion. So, we ask that question... precisely how long? If the answer is longer than 10 minutes, something is clearly wrong... perhaps a thermostat isn't working.
  15. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Yes, I would rather waste EV range instead. It is cleaner burning in most cases and cheaper to purchase. I have a Volt so I have range to spare when I am not commuting so this allows me to relax and not stress out about conserving every mile of range like I did when I had a PIP. Some people don't want to change the way they drive. For those people a car like the Volt or CMAX Energi are a better option. Both cars have more EV range and more power.
    I agree that the ICE should not be running for 10min, however. :)
  16. uropip
    uropip Member
    138
    38
    S.E. MASS
    2013 Prius Plug-in
    Silly question.... are u using the heat?
    SCH-I545 ? 4
  17. bisco
    52,880
    i wonder how the o/p made out at the dealer?
  18. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    I don't really care if that person gets in front of me. We all get there at the same time.
    iPad ? HD
