"In neutral too long" light in car wash
Discussion in 'Gen 3 Prius Technical Discussion' started by Paranormal Rob, Aug 10, 2017.
  1. Paranormal Rob
    Paranormal Rob Active Member
    244
    107
    RDU NC
    2013 Prius v wagon
    Its hard to see but its the big P with an arrow. Research shows its an alert the car has been in neutral for extended amount of time.
    I get this every time I go thru a soft cloth car wash and my battery also drains down to 1 bar. I can have an almost full charge and that 2-3 mins in a car wash it's gone.
    Why is this and is there a workaround?
    52,864
    the battery is running the a/c. the only thing you can do is not use a/c, or not use the car wash.
    Raytheeagle likes this.
  3. fuzzy1
    10,714
    And turn off any other accessories in addition to the A/C. That includes headlights.
  4. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
  5. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
  6. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    The workaround part was mentioned (turn off all electrical consumers when in N), but the why part is the hybrid synergy drive is disconnected in N, and there is no way to recharge the traction battery. In P, for example, your ICE will start and recharge the traction battery when needed.
  7. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    That's only part of the story.
    Also the ICE won't run to recharge it either while it is in N.
    I've never had a problem with that and my C's.
    I think I would be slightly concerned if the Hybrid battery went from "full" to "empty" in the space of only 3 minutes.
    But I've probably never gone through a car wash when the A/C was going full blast either.
  8. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
  9. Sam Spade
    2,036
    1,024
    2017 Prius c
    In that case, you might want to do a couple of controlled tests......without the distraction of all the car wash equipment........where you pull into a parking lot when the battery gauge is near the top and put it in N and actually time it to see how long before the warning comes on.
    Peoples "gut feeling" about the passage of time often is WAY off.
  10. bisco
    52,864
    was it going at all?
  11. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    Soft cloth car washes only take 2-3 mins.There is no "gut feeling". Cars are in front and behind so its quick.
    AC was on about 75 degrees and it was 83-84 today, cooler than it has been lately.
    I already did a test in my driveway. Parking brake on, foot off brake, in neutral. After 10 mins it dropped 2 bars, similar to when I sit in the Uber airport queue in park.
    I also coasted in neutral on long gradual downhill roads and never saw the battery level drop.
    I expected to drop some, but not from the 2nd-3rd line from the top down to 1 bar and a light popping up just by going from one end of a soft cloth wash to the other.
    I suppose another workaround would be to put it in maintenance mode first.
  12. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    I have an unlimited wash subscription so tomorrow or Saturday I'll video record it and time it to get exact data.
  13. bisco
    52,864
    i can't imagine what 'magnetic fields' inside a car wash would do to the battery charge. i've never gone through one, but it has been reported here many times over the years.
  14. Sam Spade
    2,036
    1,024
    2017 Prius c
    Something doesn't add up here.
    3 minutes is 3 minutes.
    The fact that it's going through the car wash should be NO different than your driveway test.
    Sitting in PARK is different though as it will run the ICE to recharge the battery as needed.
    I know that you will reject this idea out of hand but the most likely "cause" of this is that the observer has made a slight mistake in "recording" the details of the event.
    A "work around" should NOT be necessary.
  15. Sam Spade
    2,036
    1,024
    2017 Prius c
    And most all of those "reports" are from people who don't realize that the battery is not being recharged when in Neutral.
  16. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    And you don't know that. You're assuming.
  17. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    I did some more searching and found this as well, although just turning everything off seems just as easy. Either way, I'll turn off anything I can using power and see what happens. I thought the 12v battery controlled all of that anyway, not the hybrid battery.
    "You can actually put the car in IG-ON and in neutral. This would eliminate the HV battery draw, and assuming the blower and other accessories were off, wouldn't tax the 12V battery either."
  18. Sam Spade
    2,036
    1,024
    2017 Prius c
    Give it a rest, Rob.
    Yes I DO know that because I remember a lot of the message threads that resulted.
  19. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    Well...if the A/C is on, don't the A/C control sensors also sense humidity? Could the increased humidity in the car wash cause the A/C to run at higher power, increasing the electrical load?
    Paranormal Rob and bisco like this.
  20. bisco
    52,864
    good thought.(y)
    any draw on the 12v is recharged by the hybrid battery, so that would be a wash.
