In-vehicle Trickle Charging a Dead Traction Battery ?
Discussion in 'Gen 2 Prius Main Forum' started by jimolson, Oct 30, 2023.
Tags:
  1. jimolson
    jimolson Member
    162
    63
    Indianapolis, USA
    I loaned a family member my 2007 Prius without telling her that the gas gauge is drastically inaccurate. (Two bars means you're close to walking).
    As you might guess, she ran it out of gas and continued to drive until the traction battery was depleted. There is no longer sufficient charge in the traction battery to start the vehicle. I had it towed back to my garage.
    I recently purchased a Meanwell-branded LED driver module (called an "E-ballast" in the old linear fluorescent days) intended for driving LED lighting strings in the range of 150-250VDC. Its output current is roughly 300mADC. I have electrical engineering training that allows me to work on a 210VDC Prius traction battery without getting shocked or burned.
    Question #1: Someone elsewhere in this forum suggested that disconnecting the 12VDC battery will cause the engine computer to reset and, when 12V is re-applied, the computer will reboot itself with the false presumption that the traction battery has 60% state of charge. The poster believes this will cause the vehicle to attempt to restart one last time.
    Does anyone know if this is true?
    Question #2: How can I use my 350mADC LED driver to trickle charge the traction battery sufficiently to re-start the ICE? Specifically, does trickle charging require removing the traction battery's cover or can its 210VDC terminals be accessed elsewhere in the vehicle? I assume that the high current relay in the traction battery enclosure makes trickle charging difficult.
    Thanks to anyone with advice to offer.
    Jim Olson
    Indianapolis, IN US
  2. PriusCamper
    PriusCamper Senior Member
    13,472
    5,439
    Pacific Northwest, USA
    I think most of the answers to your questions will be found here: Build Hybrid Battery Maintenance Gear For Under $100 | PriusChat
    Brian1954 likes this.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    1) It depends. Pulling 12V power will "reset" the SOC value, but if the pack voltage is too low, it still won't try to do anything.
    2) You do have to pull the interior panels and metal cover over the battery ecu in the pack to access the connections at the HV contactors.
    I have read that if you "just" attach the meanwell to the pack you will damage the power supply. I think the meanwell needs to be plugged in first? - I would put a diode in to prevent the pack from backfeeding the meanwell instead (but I haven't tried any of this myself).
  4. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Yes. I added a switch between the Mean Well and HV bat. I did not add a diode. Power up the MW with the switch off and the MW connected. Before turning on the switch read the HV voltage with a voltmeter. Turn on the switch. It will take about 20 hours to charge the HV bat enough to start the car. Do all this with the 12 v bat disconnected until ready to start. You may need to push the power button twice to get the ready light.
    I’ve done this many times.
    It might be helpful to try to keep the HV bat cool while you do this. I don’t bother to cos my HV bat is already bad.
    #4 JohnPrius3005, Oct 31, 2023
    PriusCamper and bisco like this.
  5. Goodcitizen
    Goodcitizen Member
    75
    30
    Cali
    I bought a maxxvolts traction battery charger to keep the original nimh battery alive as it was failing. This product works perfectly for what you're trying to do. It even comes with a beefy harness to connect everything. I switched to project lithium and kept the harness installed but haven't and won't need it for many years.
    It'll charge the whole pack as one unit. Prolong also makes a similar charger it's just even more expensive.
    Also there's a chicken dance you can do to reset the gas guage calibration. Mine seems to be pretty damn accurate. With it showing 3 bars it takes just over 8 gallons to fill. I know some people have had bladder shrinkage issues so it may not help but it's worth a try!
    Just google/youtube prius gen2 gas guage recalibration.
  6. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    You shouldn't use a grid charger on Lithium ever.
    It doesn't 'reset the gas gauge recalibration', it calibrates the inclination sensor in the combination meter (CM) so the car knows whether it is level or not. The only time that you need to calibrate the inclination sensor is if you've removed and replaced the CM so, it's not worth a try as it won't help.
    There is probably more bad information on sites like YouTube and found by search engines like Google. The trick is how finely tuned your BSmeter is so you can reliably work out the difference.
    #6 dolj, Nov 1, 2023
    JohnPrius3005 likes this.
  7. jimolson
    jimolson Member
    162
    63
    Indianapolis, USA
    Thanks for the great feedback, gentlemen.
    I studied up last night (using internet resources) on the design of the Gen 2 battery pack, and Mr_guy_mann is correct that there is no easy access to the battery stack's terminals.
    In fact, I was surprised that the high current loop out of the battery pack to the inverter is not connectorized. I can imagine that Toyota engineers doubted the long term reliability of a 150 amp connector, a reasonable fear.
    The most convenient solution for my depleted NiMH problem would have been a low current (~1 amp) charging port integrated into the removable shut off plug. The plug was a custom-molded device anyway at the beginning of the Prius program.
    That there is no conveniently-mounted low current charging connector for the NiMH battery shows that Toyota believed the self-discharge rate of their battery was extremely low. They certainly understood that business circumstances (recalls, parts shortages, etc.) would strand some unsold Prii in parking lots for months.
    The hot trick would have been a simple circuit in the main inverter that, upon software command or via a hidden metallic switch, would have used the 12V battery rail to trickle charge a depleted traction battery. This charging method would necessitate an external charger on the 12V battery during use, but it would be a clean, zero labor solution to depleted traction batteries.
  8. JohnPrius3005
    423
    235
    Yeah, marketing and manufacturing products is a complex process. My take on Priusses is that their prime target market was/is those looking for high mileage transport without having to accept a minuscule, low performance engine. Hence hybrids. But they come at the cost of very high complexity. Also, regarding the question of longevity and durability. What is the vehicle's design life? Again, my take on this is that Toyota planned on about 150,000 miles. Due to complexity, among other factors, they offered a long warranty on various drive train items. After that period, ie after the design life, you are on your own. Dealers may be able fix problems (and even charge HV bats), but at a high cost. Introducing easy/DIY ways to charge a deleted HV bat (which was designed to go the full 150,000 miles without failure) would have only opened liability and other unintended, and unacceptable, avenues for unforeseeable issues. At least the preceding is my take on the possible reasoning and logic behind various features of these cars. Keeping customers happy who, like many of us here, choose to operate their vehicles beyond their intended service life, is definitely not a priority. Owners who scrap their vehicles at or before their service lives are the ideal customers. And many of us with Priusses with below 150,000 miles are pretty impressed.
  9. jimolson
    jimolson Member
    162
    63
    Indianapolis, USA
    John, thanks for the thoughts, and let me use them as a soapbox for my own.
    I'm a bit disenchanted with Toyota's customer experience from vehicle purchase to scrapping it, and might consider another brand when I buy an EV. But, in fairness, I think Toyota probably isn't much different from other manufacturers except maybe Rolls or Bentley.
    As a car buyer/user I see Toyota as a besieged corporation living in a walled fortress, driven there by state and federal governments and plantiff's lawyers. (Ex: 600 page owners manuals that warn you the dashboard gets too hot to touch in the sun.)
    Toyota cautiously builds cars and pushes them through the fortress wall to dealerships who (mostly) set their own rules and define the customer-facing experience. The recent "market adjustment" pricing stuff is a good example of dealers going their own way.
    Modern business schools teach graduates to keep their eyes on high-level performance metrics and de-prioritize the crisises of the day. Translated, if market share this year is a half point higher than last year's it doesn't matter that customers think you suck. Numbers are what matter.
    Dealerships act as if their targeted customer is a 75 year old senior flush with cash, never owned an air compressor or wrench, never patronizes the parts department except to purchase rubber floor mats, and simply wants a pristine driving experience to match their hoped-for stress-free retirement. Dealers apparently think that any deviation from that sterile business model encourages Toyota to franchise a new dealership down the street.
    I would love to see a mainstream car manufacturer bold enough to sever their parts and service functions from their car selling entities. Frankly, most car purchasers just endure the dealership experience and acquire parts and service elsewhere.
  10. JohnPrius3005
    423
    235
    Yes, indeed. To see the positives in this situation: it does leave a lot of room for innovators and independents. Tesla selling their cars directly is a small step in the right direction, albeit with many flaws.
  11. highmilesgarage
    highmilesgarage Active Member
    494
    185
    Kansas City
    when I grid charged my bad HV battery I just left the connector wires/plug connected just in case I need to grid charge again. You need to remove the trim on the driver side (same process when removing the shock absorber on that side) and the terminal cover is accessible to connect the wires for charging.
  12. BiomedO1
    BiomedO1 Senior Member
    4,636
    2,434
    Left Coast
    FWIW; first generation Ford Escape hybrids had this function. Button was hidden in the lower drivers side kick panel.
    Toyota did the math and decided to not spend the $0.05 per unit, on a switch that 99.5% of their customers will never use.:p:whistle::oops:
    Besides, it becomes another revenue stream for their dealers - win/win :notworthy::cry::sleep:
