Incessant beeping!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by geerad, Jun 25, 2017.
  1. geerad
    geerad Junior Member
    Fresno, Ca
    I have a 2004 Toyota Prius and it runs great, but while I am driving it continuously beeps. I recently replaced the the electronic water pump and the coolant control valve. I have used a scanner and it indicated no codes. Plus, I just had my car smogged yesterday and it passed.
    --The beeping sounds like 3 beeps every 5 to 10 seconds and is continuous.
  2. JC91006
    16,863
    8,617
    Try putting your keyfob in the key slot to start the car, see if the beeping goes away
  3. geerad
    Fresno, Ca
    I tried that and it didn't work. I also checked my battery in diagnostic mode and no problem there. And I checked the FOB, and it was good as well. I have spent hours trying to figure this out but haven't had any luck.
  4. JC91006
    16,863
    8,617
    Try resetting the car, disconnect the 12v battery negative for a minute
  5. geerad
    Fresno, Ca
    I did that as well and had no luck. Could temperature have anything to do with it? Where I am at it is about 105 degrees daily.
  6. JC91006
    16,863
    8,617
    What scanner are you using?
    If you recently worked on the cooling system, I would check to make sure the radiator is full.
  7. JC91006
    16,863
    8,617
    Only time I hear 3 beeps is when I have a door open. Maybe you should check all doors and also the hatch
  8. geerad
    Fresno, Ca
    I used a couple scanners and just had it smogged and it passed. Checked the coolant multiple times and it's good. It was my first time draining and refilling the cooling system so that leads me to think I might not have bled the system well enough. I am going to bleed it again. Could that be the source of the beeping?
  9. JC91006
    16,863
    8,617
    No need to bleed again if it's full. Check all your doors are shut, including hatch
  10. geerad
    Fresno, Ca
    I thought it could be a door problem as well but should a warning light come on as well?
  11. JC91006
    16,863
    8,617
    Yes there's a door ajar light. But I can't think of anything else with 3 beeps
  12. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    Some one has left a smoke detector under a seat ?? I once used a pair of airplane headphones to locate a beeper running out of batteries.
    iPhone ?
  13. JC91006
    16,863
    8,617
    Or alarm clock/watch
    Paul Schenck likes this.
  14. geerad
    Fresno, Ca
    I think it is something simple like the hatch. I am going to tinker with it all day tomorrow till I find out how to fix it. I'll post the what was causing it, if I figure it out. I just signed up on this site and I got responses quick. I'm glad I found this site. Thanx for all the input!
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Is the seat belt blinking on the dash in front of the passenger seat. If there's a lot of weight on the passenger seat the seat thinks there's a person seated and will nag the seatbelt beeper for that seat.
  16. dolj
    dolj Senior Member
    8,603
    4,364
    Wellington, New Zealand
    It doesn't have to be a lot of weight either. I once had it happen that the beeping would only occur when going around corners or over bumps. Turned out to be what I had on the seat, even though it didn't beep when I put it there because it was so light. Took me a long time to figure out too, as the passenger seat belt light is not really in your line of sight from the driver's seat, so never caught my eye until I looked directly at it.
    The fix, move the parcel (or whatever) to the floor, or do up the seat belt.
  17. Paul Schenck
    524
    307
    Fresno, California
    Ok, you've tinkered "all day" on it, what have you learned? Here on Prius Chat you've got to put up or shut up
    iPhone ?
  18. Paul Schenck
    524
    307
    Fresno, California
    What have you learned?
    iPhone ?
