Incorrect Range Information
Discussion in 'Prius v Main Forum' started by Nicaaz, Apr 4, 2013.
  1. Nicaaz
    Nicaaz Junior Member
    16
    Toronto Canada
    2013 Prius Alpha
    it's showing 7km left with 2 bars
    Anyone has this problem with their prius V?
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    It is not a problem. It is to prevent fools from running out of gas and potentially destroying the HV battery with highspeed emergency EV use.
    The car says you should fill up in 7km. It will continue to work for maybe 100km with 0km showing on the dial.
    JimboPalmer has a great way of thinking about it:
    So the 0 range at 2 pips seems to be automatically geared towards spousal relationships. When the car says 0 at 2 pips fill up unless you can live with the consequences. You should always have an extra amount of gas handy. You could be coming home on the 401 and a tanker overturns stranding you in one of the lanes for 6 hours while they remove the truck. If you were running on fumes, that would be a horrible experience and you would probably need a tow from the middle of the 401. If you had 100km of reserve, you can sit idly in READY for a long while.
    F8L likes this.
  3. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    I've seen 4 miles remaining at zero pips.
  4. sURFNmADNESS
    sURFNmADNESS Prii Family
    199
    48
    Omaha, NE
    Yup. I have had mine read 9 miles left and had the last led blinking.
    BTW, I have had the problem of my speedometer reading KM too. I just simply hit the big MILE/KM button on the dash to correct it. ;)
  5. schmuly
    schmuly Member
    209
    51
    BC
    You also get a loud "bing" and a gas light icon comes the dash, we have traveled 35km after that to a gas station (with spare full gas can in back) filled the prius up , subtracted the number on gallons from what the tank holds in the manual and it showes we still had 1.25 gal left in the tank. Roughly 60 miles or 100km left in the tank.
    This was in the US just south of where we live. I know I heard that the fuel pump needs gas for cooling but doesn't the gas that it draws through the fuel line cool the pump?
  6. vlady
    vlady Junior Member
    42
    Issaquah, WA
    I just put 10.8 gallons. drove 50miles after last bar disappeared. 2 bars somewhere in 75-100 miles range. Reset trip after fill up. There are 3 different trips and sometime you get confused
