Increased engine noise/road noise and decreased MPG?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by KenP3_tr73, Sep 9, 2024.
  1. KenP3_tr73
    KenP3_tr73 New Member
    Rochester, NY
    2012 Prius 3 with 140K miles. Within the past week or so, there is now a noticeable increase in noise that at first I thought might be road noise, but now I think that it is engine or transmission noise. The sound frequency, and to some extent the volume, changes smoothly with the speed of the car. Higher MPH equals higher pitch and somewhat louder, too. It almost seems like the RPM's are too high and the tranny should drop into the next gear, but is this a thing with an ECVT? It's not a rattle of any kind, and I don't notice any difference in response from the gas pedal. Also, we're in the middle of a 1000mi road trip and the MPG's have dropped from typically 51mpg to 45 mpg. What should I suspect?
  2. Kromis
    Kromis Junior Member
    Rosemead
    2014 Prius Plug-in
    I've been experiencing something similar but haven't found what the issue is yet. Will be watching this thread.
  3. KenP3_tr73
    Rochester, NY
    It occurred to me that maybe the car is running in "B" mode (engine braking) instead of Drive, even though the display says that I am in "D". Is this possible?
    52,886
    could be a weakening hybrid battery causing the engine to work harder. is it hot? any large hills?
  5. KenP3_tr73
    Rochester, NY
    Uphill, downhill, level, cool morning, hot afternoon--- no difference! The noise seems to be tied to the speed of the car, not how hard the engine is working. MPG update: for the next 200 miles of the trip I kept it right at the speed limit (max 70 on highways) and I averaged 55 mpg on that segment. So maybe whatever is causing this noise is not causing a decrease in MPG after all.
    Kromis and Brian1954 like this.
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,129
    6,982
    Texas Hill Country
    Wheel bearing/hub
    KenP3_tr73 likes this.
  7. KenP3_tr73
    Rochester, NY
    Spot on, rjparker! Both the front and rear wheel bearings on the right side needed to be replaced. Had it done at a dealer, and all is quiet again. Thanks for your help.
    Kromis likes this.
