Increasing EV range
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by drsacha, Aug 3, 2018.
  1. drsacha
    drsacha Junior Member
    29
    Tempa, FL
    Is there a product offering that can increase EV range of PIP 2012 given battery technology has improved since PIP launch.
    Data Daedalus likes this.
    52,863
    yes, it's a sweet little unit called prime. more than doubles the range.(y)
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    I keep hoping that @jeff652 will have something ready by the time our PiPs are needing it. But I'd understand if he didn't see enough market potential to warrant the investment.
    52,863
    would reconditioning increase range?
  5. jerrymildred
    11,517
    14,171
    Tampa, FL
    Only if the cells were out of balance or otherwise degraded. I'm not aware of any real data on the behavior of the cells like what is available for the NiMH batteries.
  6. bisco
    52,863
    gotcha. i was thinking o/p had a healthy battery and wanted to add more.
  7. jerrymildred
    11,517
    14,171
    Tampa, FL
    I was assuming the same. If we could recondition, I would think there would be some improvement in EV range, but only in proportion to how out of balance and worn the cells are.
    Data Daedalus and bisco like this.
  8. drsacha
    29
    Tempa, FL
    Was also thinking inline of if there are businesses that have come-up with better battery to replace the original ones. And that gives an increased EV range.
  9. bisco
    52,863
    not that i have seen, not enough pips on the road to make it worthwhile. plus, i'm not sure how much batteries have improved. prime is a huge battery compared to pip, to get more miles.
    if you dropped prime battery tech into pip battery box, you might get a few more miles, but there are other improvements on prime that increase range besides battery.
