Independent/Experienced Prius Mechanic needed on Long Island, NY
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tmoose57, Jun 8, 2015.
  1. Tmoose57
    Tmoose57 New Member
    Huntington, NY
    Yup, I'm a NEWBI. I am researching buying my first used Prius and kept finding the answers to my questions on this site. So, I signed up and am posting for the first time.
    I've narrowed down my choices to a 2010 or 2011 Prius ll/2, lll/3 or lV/4 Hatchback. Am looking for input from those who have been there/done that.
    1. I've read of suspension improvements made between model years 2010 and 2011.
    Are these changes (and any other improvements I haven't heard about yet) worth spending the extra bucks for 2011 model?
    2. If the mileage is roughly equivalent, are the two model years also equivalent?
    3. I've read, on this blog, that opinions differ between about going to a dealership or not to make the purchase. What are the reasons for this difference?
    4. If i do go to a dealership, is the "Certified" tag worth the extra money or just another bit of fluff?
    5. If I buy from a private seller, I assume that I should take the car to a Toyota dealership for a Pre-purchase inspection. If I buy from a dealership, where should I take the car for said inspection?
    6. Hence, the need for an Independent/Experienced Prius Mechanic. Anyone have any recommendations or referrals?
    7. My #1 reason for favoring the trims lll/3 and lV/4 is the Bluetooth/Audio options. Are these justifiable increases in cost or should I get a II/2 trim and look into aftermarket upgrades?
    Thank You, Any and All for your help and sharing of knowledge.
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
  3. mrbigh
    3,686
    699
    Long Island, NY
    I really can't recommend any because I never used a mechanic other than myself to perform basic maintenance ( oil, brakes)
    The only time that I was in need off was to do a 4 wheel tire alignment and it took me 5 trips to the f**ng tire repair shops to leave it as it was before. Can I recommend something like that?
    Probably by today days and after 16 years of Prii on the road, it would be some fine car mechanics. I will suggest a Toyota stealership for advanced troubleshooting and/or diagnostics.
  4. onlyturbo
    onlyturbo New Member
    Long Island NY
    Just bought a 2013 Prius two, I am also looking for a good honest Prius mechanic in Western Suffolk Long Island NY.
  5. IDs mak
    IDs mak Junior Member
    31
    Ny
    They are high in demand and short in supply
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    This has been discussed fairly often here and the consensus is:
    A 10 year old hybrid, presumed to have fairly high mileage, probably is NOT a really good choice in a used car.
    The first owner usually reaps most of the hybrid benefits.
    Subsequent owners end up with enough extra maintenance costs that the extra gas mileage is more than offset.
    The simple fact that you have so MANY concerns should be ample evidence for an impartial observer.
