Induction Reasoning......
Discussion in 'Fred's House of Pancakes' started by ETC(SS), Jan 17, 2023.
  1. fuzzy1
    10,687
    Only one of five commissioners said it, and included it as just one of several possible regulatory paths. Other commissioners went on record as opposing that one path.
    Reductio ad absurdum.
    .. especially the big orange clown. But his attention span is much too short to read it.
    We have used camp stoves outside to cook during past power outages. But during the more recent outages, it was much more convenient to use a common food service portable butane burner inside. It seems that while not completely CO-free, they are much better than the others.
    #21 fuzzy1, Jan 17, 2023
  2. Leadfoot J. McCoalroller
    8,271
    7,775
    Pennsylvania
    2018 Prius c
    I put more than 20 hours on the new generator last year according to the hour meter.
    Outage SOP is to set up a propane camp stove on top of the electric range in our kitchen.
    The generator isn't powerful enough to run the cooktop (old or new) but it's plenty to run the commercial-sized ventilator in our kitchen.
  3. ChapmanF
    18,959
    That works great for your top burners. Trouble is, for the oven, you need to be around with your match again every time the thermostat wants to cycle the burner on again.
    Standing pilots, thermocouples, and millivolt gas valves just keep on tickin'.
  4. Trollbait
    12,806
    Also an issue with using a match or piezoelectric back up for furnaces, and boilers, and hot water appliances.
  5. BiomedO1
    BiomedO1 Senior Member
    4,527
    2,381
    Left Coast
    I was surprised my low NOx water heater still uses a standing pilot along with a thermoscouplers to drive the safety cutoffs. The pilot has blown out several times, but it usually fires right back up. Unfortunately that means that I shower at work.;) Gotta clock-in on time.
  6. tochatihu
    tochatihu Senior Member
    9,943
    3,844
    Kunming Yunnan China
    2001 Prius
  7. mikefocke
    4,073
    1,858
    Sanford, NC
    Propane bar-b-q grill works. As does a propane fireplace with optional battery starter.
  8. dbstoo
    dbstoo Senior Member
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    If you have a gas stove, there is no reason that you can't run it's 120V power cord through a UPS during a power outage. They run a fairly long time if you don't have much of a load on them. I'd think that the spark igniter is pretty low power.
  9. ChapmanF
    18,959
    Just reading up on the glass-ceramic sheets they use for the tops of these things. Same stuff they use for the smooth-top conventional-resistance ranges. They're pretty transparent at infrared, and the conventional smoothtops aren't really heating them by conduction from a heating element; they use an element optimized for giving off infrared in a range that shines through the glass-ceramic and heats the pot. (And heats the glass-ceramic some too, because it's only mostly transparent to IR.)
    Funny way to think about it ... both the conventional smoothtop and the induction cooktop are passing some frequency of the electromagnetic spectrum through the glass-ceramic sheet to wiggle some of the matter in the pot. The induction cooker is using a frequency around 40 kHz and the conventional one is using a frequency somewhere in the tens to low hundreds of THz.
    But the similarity only goes that far, because if the pot isn't there, inductance puts a limit on the power flowing in the induction coil below, whereas the IR source keeps radiating the same amount of IR anyway, shining through the cooktop and wiggling whatever other matter happens to be on or above it.
    #29 ChapmanF, Jan 17, 2023
    Trollbait likes this.
  10. Trollbait
    12,806
    I imagine the issue would be in getting to the oven plug whenever to power is out.. Probably not enough space behind the range for the UPS.
  11. ChapmanF
    18,959
    UPSes can be made pretty small these days, and gas stoves use a pretty negligible amount of power.
    Maybe gas ranges should be offered with UPS designed in.
    Heyyyyy, I've got it: an optional standing pilot. The power goes out, you open the valve, light it with a match, and a thermopile and boost converter run the electronic controls.
    But maybe manufacturers who read writing on the wall will not be making a lot of investment in gas stove redesigns going forward.
    #31 ChapmanF, Jan 18, 2023
  12. Todd Bonzalez
    Todd Bonzalez Active Member
    250
    160
    Ireland
  13. Leadfoot J. McCoalroller
    8,271
    7,775
    Pennsylvania
    2018 Prius c
    ...which starts a a 24 hour count-down to close the valve and cut off the temporary emergency pilot. Way too open to abuse if left as a full-time mode.
  14. ColoradoBoo
    ColoradoBoo Senior Member
    1,338
    961
    Monument, Colorado USA
    Oh yeah, Orange Man was SO bad....how did we stand the 28% improvements in our 401K and investments but, thank Goodness we now have -15%...only trillions of dollars wiped out from our retirement accounts! And how did we ever survive on STOCKED grocery shelves and eggs only costing $2 a dozen?? Let's rejoice at our 10% inflation and at the fact that over 10% of our elderly retired folks are saying they have to skip meals because they don't have enough money to eat three meals a day. But orange man gone...disregard a baffoon who steals classified documents and doesn't even know how to store them (in a GSA-approved safe in a secure building) and rents out his house for $50,000 a month to his son...no money laundering or "paying the big guy 10%" going on there, huh?
    jdenenberg likes this.
  15. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Sarcasm is a low form of humor. but I liked it.
    JeffD
    ColoradoBoo likes this.
  16. ETC(SS)
    7,503
    CNN Opines......
    Opinion: The great gas stove debate has been reignited | CNN
    Keywords: "it is entirely possible....."
    I seem to remember something about a camel and a nose.....;)
    It's kinda cute to read about people surviving without electricity for a few hours after a storm....but the first time I ran my dual-fuel genset after a hurricane it was on-line for >24 hours.
    My longest period of electrical outage in the last 20 years was eight days, with some twos and threes sprinkled in.
    After 7 days or so, one might appreciate being able to take a warm shower.....or cook a meal...or heat a home after an ice storm...and YES those DO happen where there are hurricane force winds.
    HOWEVER
    (Comma!!!).....those are relatively minor issues as compared with the glaring fact that, as CNN states, unchallenged by $cience....
    "(cited by the CPSC without challenge or comment) .....over 12% of childhood asthma cases in the US are the result of gas stove usage."
    -really?
    SO, of 40% of American homes have gas stoves, and "12% of childhood asthma cases in the US are the result of gas stove usage"
    WHY ARE THEY NOT BEING BANNED IMMEDIATELY as a clear and present health hazard?!?!?!
  17. ChapmanF
    18,959
    S&P 500 Jan 2017 close 2362.72 Jan 2021 close 3972.89. (Interactive graph here, I didn't try to drill for specific days of the month).
    Over that four-year period, that's a per-year growth of ...
    Code:
    >>> pow(3972.89/2362.72, 1/4.)
    1.1387373637745093
    ... 13.9 %.
    The guy before him covered eight years, starting from 797.87 in Jan 2009, or ...
    Code:
    >>> pow(2362.72/797.87, 1/8.)
    1.1453415477197224
    ... 14.5 %.
    So I guess we "stood" the one guy's 13.9% pretty much the same way we "stood" the earlier guy's 14.5%.
    We're currently two years into this guy's term and essentially flat (entered office at 3972.89, yesterday's close 3990.97).
    What makes that come out flat is a prominent slide you can see in the graph between Dec 2021 and Oct 2022. If you pick the 12/26/2021 peak (4778.73) and the 10/9/2022 valley (3583.07), on paper you lost 25% in those 10 months.
    If you picked a similar period leading up to Jan 2009 (ok, the CNBC tool lets me grab 4/2008, 9 months, or 1/2008, 12 months), you were down 38% for the 9 months, or 40% for the 12 months.
    If you picked Jul 1987 at 321.83 and Oct 1987 at 247.08, you were down 25% in a single quarter. I made my first-ever market investment in August that year, so that was kind of memorable. But I stayed in, and that paid off.
    Nobody likes when those things happen, but if you can't stand them, stocks maybe aren't the thing for you.
    Sometimes it helps to look at what's happening in other countries around the same times, to get a sense of perspective.
    fuzzy1 and Trollbait like this.
  18. jdenenberg
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You have to consider the cost of banning such a widely used appliance, one could encourage the use of proper ventilation instead..
  19. ChapmanF
    18,959
    So, that CNN article you linked is itself full of links to studies and to earlier reporting, including by CNN, with its own links to and/or citations of the studies you here portray CNN as accepting from CPSC without challenge or comment.
    Choosing not to repeat themselves when they've done that reporting earlier isn't the same thing.
    I'm happy to see that CNN article also links to the Grist article reprint with the history of how the whole idea that gas stoves were, well, "cooking with gas!" was drummed up by the gas lobby in the 1930s. I hadn't seen that in this thread yet.
  20. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    backup backup backup
