Inexpensive front sway bar upgrade
Discussion in 'Gen 3 Prius Accessories and Modifications' started by toyotechwv, Jun 5, 2012.
  1. toyotechwv
    toyotechwv Toyota Technician
    474
    254
    Princeton, WV
    Just an fyi, no need to spend big money on Cusco and Tanabe bars which are 1mm thicker than stock. Just installed a bar from a 2011 Rav4 Sport on my 2011 for less than $100 new. This bar is 1mm thicker than Prius front bar. Definitely much flatter cornering, much less roll.
  2. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    Interesting, got any pics?
  3. BreitrthnU
    BreitrthnU Can you smell the premix?
    255
    50
    Tampa, FL
    Good info thanks for posting. I was lucky enough to get a new tanabe front sway for 73 bucks shipped. Got lucky on fleabay!!!
  4. ikagan
    ikagan Junior Member
    61
    Aventura, Florida
    Paul, did you also use the stock Rav4 swaybar bushings/brackets?
    Do you have the OEM part numbers?
    Thanks.
  5. BlackPrius30
    BlackPrius30 Junior Member
    30
    For 100 bucks, I rather get aftermarket....
  6. toyotechwv
    474
    254
    Princeton, WV
    I did use the Rav bushings but used the Prius brackets. Install wasn't terrible but the lower control arm on one side has to be unbolted from the cradle to get the bar out. Will get part numbers and post.
    WE0H likes this.
  7. toyotechwv
    474
    254
    Princeton, WV
    Why, so you can say you bought an aftermarket part instead of factory? Best part about the Rav bar is it looks stock but out performs the original piece. I don't need a Tanabe sticker on my car, ill save every penny I can on upgrades.
    abra, WE0H and lensovet like this.
  8. peterjmc
    917
    189
    Clarksburg, MD
    Now the question is... where could we get an inexpensive rear swaybar from? :)
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Thanks, Paul!
    I agree. In most cases the OE equipment is better than aftermarket anyway or it is at least reliably built.
  10. BreitrthnU
    255
    50
    Tampa, FL
    If I paid full sticker on a tanabe Id be hurting now. This is a no brainer hopefully for everyone. Dont forget to hit up the junkyards too.
  11. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Nice find. Thx
  12. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    Was thinking about hitting up some junkyard for this, wow does the PiP sway a lot on turns.
    Is this bar only the Rav 4 Sport? Is that what I should ask if they have?
  13. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    I was wondering the same. Does the Rav 4 Sport have a thicker sway bar than a non-Sport version?
  14. toyotechwv
    474
    254
    Princeton, WV
    I didn't compare the Sport to the other packages but I'll ask my Parts Dept. and see if the part numbers match.
  15. BlackPrius30
    30
    Aftermarket is thicker? A better upgrade then only 1mm??
  16. xliderider
    8,140
    3,280
    Honolulu, HI
    1mm doesn't sound like much difference, but it does add torsional rigidity over a thinner sway bar. Too much of a good thing is also bad.
  17. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    What is the part number you purchased?
    I saw different version Rav 4 ones.
    Where did you get it for less than $100?
    A quick picture of it installed from under the car would be nice.
  18. Totmacher
    Totmacher Honey Badger don't give a carp
    301
    110
    Mission Viejo, CA
  19. toyotechwv
    474
    254
    Princeton, WV
    Bar is 48811-0R010, bushings are 48815-0R010, 48815-0R020. Will try to post a pic later today, installing wheel spacers so ill take some pics while the car is on the rack.
    WE0H likes this.
  20. BreitrthnU
    255
    50
    Tampa, FL
    Any chance you could explain how you got it installed. I tried changing out the front swaybar last weekend with no success. I read somewhere that you have to take off a control arm.
