Inexpensive front sway bar upgrade
Discussion in 'Gen 3 Prius Accessories and Modifications' started by toyotechwv, Jun 5, 2012.
  1. toyotechwv
    toyotechwv Toyota Technician
    474
    251
    Princeton, WV
    Unbolted the drivers side lower control arm. I left everything else attached including the wheel. Had a 2nd person pull and hold it away from the cradle while I removed the old bar and slid in the new.
    PC36100 ? 2
    Totmacher likes this.
  2. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    Did you ever find out if the part number for the Sport sway bar is the same as the non-sport bar?
    Thanks.
  3. ikagan
    ikagan Junior Member
    61
    Aventura, Florida
    WE0H, Totmacher and Tracksyde like this.
  4. xliderider
    8,140
    3,274
    Honolulu, HI
    Thanks for the sleuthing on that information ikagan. :)
  5. Dakine50
    Dakine50 Member
    148
    22
    Nor-Cal
    Could one use the existing sway bar bushings since the bar is only 1mm larger? I have approx 3,500 mi on my car so bushings are like new. Not sure if the durometer(hardness) of the rubber would be different between the Rav4 and the Prius though. If possible, you could save another 40-50 bucks!
  6. ikagan
    61
    Aventura, Florida
    Actually, when your bushings will be more worn out they will fit the larger bar better ...
    In order to function properly the bar has to have some movement inside the bushing.
    I had a "scary moment" while auto-crossing my Miata because of sway bar bind.
    BTW, a stiffer front swaybar will make your car under steer more, not fun!
    I would add it only with a matching rear bar.
  7. toyotechwv
    474
    251
    Princeton, WV
    Depends on how hard you're driving it. I didn't understeer much today at my autocross event.
    PC36100 ? 2
  8. ikagan
    61
    Aventura, Florida
    I realy have no experiance with driving the Prius at the limit.
    I tried to push it a few times but the VSC stopped the fun very early.
    Can it be disabled for autocross?
  9. toyotechwv
    474
    251
    Princeton, WV
    Inspection mode :cool:
    PC36100 ? 2
    WE0H and Totmacher like this.
  10. Dakine50
    Dakine50 Member
    148
    22
    Nor-Cal
    Thanks for the tip, I already have the Prius plus performance rear sway bar (not sure if you would call it a matching bar) along with Tanabe SO-C coilovers.
  11. Totmacher
    Totmacher Honey Badger don't give a carp
    301
    110
    Mission Viejo, CA
    For anyone not keeping track... Here is my cheat sheet so far for an all Toyota/TRD setup, prices are estimates...
    PTR07-47100 - TRD Lowering Springs - 184.00
    PTR11-47010 - TRD Rear Sway Bar - 224.25
    PTR11-47011 - TRD Rear Sway RP - 50.98 (Not needed)
    48811-0R010 - Front Sway Bar - 74.75
    48815-0R010 - Front Sway Bushing - 17.46
    48815-0R020 - Front Sway Bushing - 17.46
    potatoesLOL, WE0H, Priusmpg and 3 others like this.
  12. ikagan
    61
    Aventura, Florida
  13. Totmacher
    301
    110
    Mission Viejo, CA
    I was curious about that also. Reasons why...
    1) Some ebay listings show it with and without.
    2) ToyotaPartsPeople.com does not carry the RP kit...
  14. Totmacher
    301
    110
    Mission Viejo, CA
    After reading that thread, if the posted information is correct, the reason behind the "PTR11-47011" Part number could be to "upgrade" the people that had the issues with the initial xB Sways with the part numbers "PTR11-52080" and "PTR11-52090"
    I found this pdf file...
    http://www.google.com/url?sa=t&rct=j&q=ptr11-47011&source=web&cd=9&ved=0CGAQFjAI&url=http%3A%2F%2Fpictures.dealer.com%2Fnewcountry%2F2ff93b010a0d02b7008210fc0c02cf56.pdf&ei=atzgT-u8CKO28AHNiNXvCA&usg=AFQjCNHjtIXbo2Hi1H4-ydGd2X9ltqlQlQ
    And it indicates the PTR11-47011 part number is for the xB which supports my above theory.
    I'm still waiting on a source of mine to see if he can beat out ToyotaPartsPeople.comprice of 251.75 shipped. If he can't I may just order the bar up by itself tonight and if I need to, get the extra kit.
  15. Delux
    Delux Junior Member
    38
    Westminster, Ca
    Let me know if he can beat it, maybe we will get a deal if we get 2 (or 3 if you get one for the 2011)
  16. Dakine50
    Dakine50 Member
    148
    22
    Nor-Cal
    ikagan, you are correct, part # PTR11-47010 does come with the end links/hardware kit.
  17. Totmacher
    301
    110
    Mission Viejo, CA
    Well I just pulled the trigger. Got the TRD springs and rear sways. Should be in for pickup tomorrow so ill have a definitive answer. 447 after tax for both. No shipping, just pickup. Best deal I could find. The RP kit is 2 weeks out so I hope its true and I don't need it. My only concern is maybe the people that got it got it from a dealer that sold the 2 together as one since the computer tells the guys they need to order both.
  18. Totmacher
    301
    110
    Mission Viejo, CA
    Well a belated update... the dog bones do come with the rear sway. any vendor charging seperate for them is screwing you.
    I can get these for less then anyone on the webs cost and if you are in SoCal you can pick them up tyically within 48 hours.
  19. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    Totmacher how much?
  20. kmkremer
    kmkremer Member
    227
    30
    San Diego
    I'm interested. How much?
