Inexpensive mods or equipment to help MPG?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Unresolved_ERR, Oct 22, 2020.
  1. PriusCamper
    PriusCamper Senior Member
    13,467
    5,436
    Pacific Northwest, USA
    You definitely got that right...
    Jim Swart likes this.
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    The thermistor DIY mod might increase emissions a bit up from essentially zero emissions during warm-up, but so does, for example, buying a non-CARB Ford Hybrid from that era. One advantage for a (non CARB) Ford Fusion vs. Gen2 Prius in that era would be the Ford was not forced to have such a low MPG when cold, so if you were a short trip person, the Ford might be as good as Prius Gen2 MPG.
    I would not recommend thermistor hack to a CARB stater, OK is OK to consider it if you are so inclined. Ideally one could try to measure emissions to make sure is within limits. I once stuck a CO detector at the the tail pipe of my non -mod Prius, and even cold I had trouble getting much over 50 ppm CO.
    Today 2020 I feel like the cold MPG is less of an issue for new hybrids, and Ford/GM might be going the 50-state route too.
