Inflating sound
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LDB, Oct 15, 2015.
  1. bisco
    52,886
    i went out to the garage one night, about 4 hours after getting home, and the car was talking to someone.
  2. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    Did you talk back? :)
    52,886
    don't speak the language.:whistle:
  4. ChapmanF
    19,049
    Fairly certain the brake accumulator is not designed to "release pressure" (on purpose) under any circumstances. Check me in the service manuals to be sure. When you want the pressure released (as, for certain service procedures, you do), you can get there by first disabling the accumulator pump, then pumping the brake pedal a few dozen times. (At least, that's how it's done on Gen 1.)
    Perhaps you heard a drop of moisture falling on a hot exhaust part, or the like....
    -Chap
  5. Mendel Leisk
    42,368
    The first time I heard that I happened to be under it, had it jacked up. Just having a look 'round, if you must know... Anyway, it scared me silly for a moment, lol.
    #25 Mendel Leisk, Oct 17, 2015
  6. bisco
    52,886
    foreign language, yes? not japanese though, couldn't make it out.
  7. Mendel Leisk
    42,368
    Sounded like 3CPO talk, near as I could tell. Maybe: "should we flatten the human?"?
  8. bisco
    52,886
    this isn't the droid you're looking for, move along.
  9. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    The "hiss" sound is the fuel system depressurizing. Through the carbon canister of course. It will, after about 6 hours, repressurize it to check for leaks. Then it will "hiss" again. ;)
    I don't remember if Pearl S' manual is the same, but Pearl's manual (GII) had two facing pages discussing the sounds the car would make. Bottom line, "any sound the car makes is normal".
  10. CR94
    CR94 Senior Member
    2,837
    1,244
    Northwestern S.C.
    I haven't yet seen an explanation for the "Whirr-thump-thump-KuLUNK" that suddenly comes from under-hood roughly one minute after shutdown. Any ideas?
  11. Mendel Leisk
    42,368
    The noise I occasionally hear, hours after shut down, is the same, as that right after shutdown sound. Your description nails it, btw.
    CR94 likes this.
  12. David Beale
    5,963
    1,990
    Edmonton Alberta
    And it's "normal". ;)
  13. ChapmanF
    19,049
    I heartily encourage curiosity about your car ... the more you understand, the better care you will be able to take of it, and the fewer unpleasant surprises you're in store for.
    As for constructive ways to pursue that curiosity, there are several common avenues for you:
    • Read the New Car Features Manual. Easy, indoors, comfy chair, any weather. You'll learn a lot.
    • Lift the hood, try to localize the sound (either with unaided ears, or a mechanic's stethoscope, they're cheap). Still pretty easy. If you've had a skim over the NCFM, see if you can connect what you're hearing to something you've read about.
    • Post recordings here.
    • Use ideas from what you've read to see if you can make the sound happen (or change when it happens). For example, does it happen sooner if you have been pumping the brake pedal?
    • Use some strategic fuse-pulling (guided by the manual, if you've looked), to see what makes the sound not happen.
    All of these are usable approaches, likely not only to allay your curiosity but also to teach you stuff.
    -Chap
  14. Mendel Leisk
    42,368
    Hah! Reading "New Car Features Manual", indoors, in comfy chair: that'd put me to sleep.
  15. ChapmanF
    19,049
    Have you tried it? More interesting than you might think. I'm on the edge of my seat for NCFM: 2016 to come out. :)
    -Chap
  16. CR94
    CR94 Senior Member
    2,837
    1,244
    Northwestern S.C.
    I know that much, but I still don't know what the sound is. At least some of it seems to come from the vicinity of the EGR valve and cooler. Acquiring that New Car Features manual doesn't seem practical for now.
