Inflating tires & tire gauge
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Oskar, Aug 15, 2014.
  1. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I use the same floor-pump as do for the tyres on my bike, plus a digital gauge. 44(front) 42 (rear)
    fuzzy1 likes this.
  2. VicVinegar
    VicVinegar Member
    275
    53
    Northern Virginia
    I have a Craftsman cordless inflator that runs off the lithium ion batteries I use for my drill. I bought a well reviewed gauge off Amazon to use as the gauge on the Craftsman is useless.
  3. Okinawa
    Okinawa Senior Member
    1,333
    320
    I have found the same, the gauge on a tire inflator is worthless. Best to get a good digital gauge like Accutire.
  4. lester williams
    227
    68
    mississippi
    Just as a FYI,, the 2 top rated tire pressure gauges by ''Consumer Reports'' is the $10--$11 ''Accutire'' ones,,, I just added one to my order of shower heads, as mine is old now. --------- [ the elcheapo ''Siroflex'' shower heads are the hands down best this 70 yo man has ever encountered ]
  5. vskid3
    vskid3 Active Member
    773
    228
    I've had this air compressor for 3.5 years and its still works great. I would recommend getting one of the clip on cigarette lighter adapters shown on the Amazon page, as the pump will blow 15A fuses pretty easily. I just pop the hood and clip it to the jump points. I use the built in gauge, hopefully its accurate. ;)
  6. lpietran
    lpietran Junior Member
    United States
    I just received a Campbell Hausfeld M6000 tire inflation gun. It's similar to Accutire. I plugged it and it deflated my tire further. Does it have to be plugged into an air source?
    st: 2058471, member: 120764"]I use the same floor-pump as do for the tyres on my bike, plus a digital gauge. 44(front) 42 (rear)[/QUOTE]
    I have a tire that I
  7. WilDavis
    2,493
    2,155
    49
    I checked my tyres over this past weekend, and a kind neighbour lent me an electric compressor, and even though it was a nice friendly gesture, the wretched thing struggled to get the pressure higher than 40psi. It was far quicker to use my Park-Tool floor-pump for my bike, and this time I set the pressures to 46psi(F) and 44psi (R).
  8. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Portable compressor...very slow, but reliable...$12 digital guage from Sears.
  9. WilDavis
    2,493
    2,155
    49
    As mentioned in other threads, I've started usig a small, portable air-compressor, but its not wise to run it through the 12V accessory socket (it might blow the fuse(s)), so I run mine from a small 12V gel-cell (see pic), or from a socket which clips directly to the charge-points under the bonnet.
    OK, campers, I've just spent nearly an hour trying to upload a picture, but each time it gets as far as selecting the file, but there's no button to actually do the download!!! @Danny, something seems to be broken!!!
    #29 WilDavis, Apr 3, 2017
  10. ChapmanF
    19,060
    I just reach in the hatch, grab the air hose, and air up the tires. :)
    (What you don't see is the refurbished Viair 450C I found online and installed down under the cargo tray.)
    -Chap
  11. Mendel Leisk
    42,380
    I've seen some sweeter ones, but I guess I'll just keep using this till it implodes:
    fuzzy1 likes this.
  12. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    I use an ancient Silca and enjoy the workout every time.
  13. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Same here, ancient Silca pump with Schrader pump head, rebuilt valve, and new leather seal. Good to go.
