[INFO] Found the source for the rear door rattle
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by soft_r, Nov 3, 2024.
  1. soft_r
    soft_r Active Member
    198
    167
    Beverly Hills
    2024 Prius
    Not sure if you hear it with stock setup. But in certain songs there will be parts that resonate with something in the rear doors. Good song to test with is Erreur 404 by L'Impératrice. IF YOU HAVEN'T HEARD THE RATTLING DO NOT GO LOOKING FOR IT BECAUSE YOU'LL NEVER STOP HEARING IT.
    That something is the mechanical latch cables. There's a few of them but the worst offender is the cable that runs vertically from the outer door handle. The solution is really easy, lash it to the horizontal running cables. I used soft velcro cable tie downs. Circled in red.
    I also zip tied the horizontal cables to the frame of the door near the center pink screw point.
    Without putting my sound dampened door trim back on this has eliminated pretty much all rattle coming from the rear. Only other door I need to investigate now is passenger front. Likely a similar issue. sdfgsdfg.jpg
  2. NullDev
    NullDev Member
    121
    63
    Ohio
    2024 Prius Prime
    XSE
    I have noticed a rattle from the rear compartment area whenever I'm on certain rough tar & chipped back roads. If I get the MPH just right, it really shakes something awful back there.
    I cannot clearly determine exactly what I'm looking at in your image. Maybe it will become more obvious once I get the door panel off.
  3. soft_r
    198
    167
    Beverly Hills
    2024 Prius
    See those two cables running horizontal coming out of the vapor barrier? There's some cables just like them running vertical just behind the metal panel (gotta peel back the vapor barrier there to get in).
    Those vertical running cables to the door's OUTSIDE mechanical button will resonate at certain frequencies and rattle awful. I noticed if I cut rear door frequencies at about 400-500hz and below it would mostly remove the rattle. But I didn't like sacrificing fidelity so I ended up fastening the vertical cables to the horizontal cables. It's not a perfect fix but it's about 98% resolved and that's probably going to be imperceptible when I get the trim back on tomorrow.
  4. Leadfoot J. McCoalroller
    8,293
    7,810
    Pennsylvania
    2018 Prius c
    ever try a simple frequency sweep when rattleproofing?
    It has worked for me in the past.
  5. Humble Bear
    Humble Bear Member
    131
    49
    Arcadia, CA
    2024 Prius
    Maybe your aftermarket amp & speakers are too powerful.;)
