Info from VIN?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PA Prius, Dec 9, 2015.
  1. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    Can the color and Base or Advanced be determined from the VIN? Or is there a way to determine Base or Advanced by seeing pics of the car?
  2. sillylilwabbit
    sillylilwabbit Active Member
    405
    118
    Los Angeles
    2014 Prius Plug-in
    If it is a 2012, the advanced has fog lights, dual led headlights.
    Larger monitor. On the door speaker, you will The initials JBL
    Sent from my
    PA Prius likes this.
  3. PA Prius
    762
    251
    SE Pennsylvania
    I'm asking because I am looking around for a '12 or '13 Advanced. My understanding is that all of these have the 8-way power driver's seat. When I see the pics on these cars some of them are showing two levers, which would appear to be manual and others have three "knobs," which would appear to be powered. All of these are listed as Advanced.
    Similarly with the fog/driving lights, which I think are standard on the Advanced. Some show round lights on the lower grill area and others do not.
    Can anyone enlighten me on these?
    52,880
    levers are on the base model, dealers don't know what they're selling. if you're lucky, you'll find an advanced listed as a base.(y)
  5. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
  6. PA Prius
    762
    251
    SE Pennsylvania
    Thanks, RRxing, this looked hopeful, but it does not report whether the VIN is Base or Advanced.
    Can anyone confirm that all 2012 and 2013 Advanced have 8-way power seats, round driving(?) lights in lower grill area, and headlight washer bumps below the headlights? If so, most of those claiming to be Advanced on cars.com are not.
  7. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    You are correct. You can't blindly trust the listing, you have to confirm by looking at pictures of the actual car. The dash is different too. The advanced has the CD slot hidden.
  8. Tideland Prius
    16,683
    Here ya go! See attached for the 2012 and 2012 PHV features/specs sheet.
