Info on Sunroof repair
Discussion in 'Gen 3 Prius Main Forum' started by Bill32803, Jan 21, 2024.
Tags:
  1. Bill32803
    Bill32803 Junior Member
    27
    Orlando Florida
    The plastic cover at the hinge at front part of my sunroof has deteriorated. I'd like to get this replaced as I am afraid of it leaking. Does anyone have any information that can help me. What part is it? Is it a chore to replace (like the headlight ) by a mechanic, body shop, dealer. Or other alternatives to covering it that doesn't involve duct tape. Bill32803
  2. Tombukt2
    Tombukt2 Senior Member
    13,855
    2,516
    Durham NC
    Is this a solar roof.car? Year. ? Amiyama may have the part. It's online schematics help.
    Bill32803 likes this.
  3. Bill32803
    27
    Orlando Florida
    It is a solar roof 2014 Prius 3. The plastic strip that runs across the very front of the opening. Maybe the cover for spring to raise the air foil that pops up? Any help would be appreciated.
  4. Bill32803
    27
    Orlando Florida
    Wow you are amazing. Found the part. Weather stripping. Amazing. Maybe it attaches with duct tape???? Thank you so much.
  5. Tombukt2
    13,855
    2,516
    Durham NC
    If it uses tape to attach usually it will come with the part or it will be specified in the service procedure that you need double-sided tape not duct tape.
  6. Tombukt2
    13,855
    2,516
    Durham NC
    There's also this stuff called goop that can be used for lots of mounting things similar to this and when need be it can be released rolled up and reapplied is necessary It works like glue but it disconnects very much unlike glue I guess is what I'm trying to say It's very good for mounting things that can be ripped off by wind force and be destroyed.
  7. Bill32803
    27
    Orlando Florida
    Tom, the info was spot on. Thank you very much. I did find the part number, but found it available here in the US from a Toyota dealer up north. Saved me $80 in shipping from Europe. I procrastinated doing it, but finally got to it. Old one came out easily since it was dry and cracked. I had to get my neighbor to help me put the new one in as it was a very snug fit. Down to just 2-3 mm extra space. But got it in pretty well. Two or three days in the sun let the part soften and fit in beautifully. Thanks again for your help. Bill
    Tombukt2 likes this.
  8. Tombukt2
    13,855
    2,516
    Durham NC
    Glad it all worked out and sunroof is proper . The only thing I miss on Gen2 no sunroof. I've had sun roofs and many of my Toyotas and most of the summer they are open. I love them I may put one in my Gen 2 traveling car.
  9. ChapmanF
    19,014
    It could be very helpful to add a photo and/or part link to this thread, from the OP who successfully found and replaced the parts. There are so many weatherstrippy bits up there, a photo might be clearer than just "plastic strip that runs across the very front of the opening."
  10. Mendel Leisk
    42,336
  11. ASRDogman
    ASRDogman Senior Member
    8,062
    4,086
    If you had laid it in the sun for 30 minutes or so it would have soften up and
    it would of went in easier.
