Initial miniVCI data
Discussion in 'Gen 3 Prius Technical Discussion' started by bwilson4web, Apr 25, 2013.
  1. bwilson4web
    16,549
    The Chinese, 'miniVCI' hack provides a pirated copy of TechStream Lite. It is not what I would call 'mission' quality but I was able to record data in my morning commute:
    It appears to record the data to a memory array and then stop. You have to save the file and start the recording again. Still, it keeps all of the data in a single file that Excel can assemble into the chart above.
    It is by no means a great solution. For example, I need to also record MG1 torque at the same time but that comes from a separate ECU. I don't know if there is a workaround.
  2. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Did you set up the Snapshot function? This function allows you to record for 5 sec. up to 60 min. and then prompt to save to a file. You can then use the built-in Graph function and playback what you 've recorded. If you want to combine PIDs or do additional calculations, the file can also be exported to Excel.
    Yes, starting from V7.xx.xxx, there is a function called Dual Data List. You can record 2 ECUs at the same time.
    Vincent
  3. motoleon
    motoleon Junior Member
    48
    16
    spain
    do you can change settings with that cable? Reprogram the ECU? Thanks.
  4. bwilson4web
    16,549
    Yes, it can change backup beep, cabin light shutoff delays and others.
  5. motoleon
    48
    16
    spain
    Can you remap de ECU?
    Fuel trims, etc?
  6. bwilson4web
    16,549
    I did not see that function but I wasn't looking. It would be useful to adjust for a high ethanol fuel and avoid the fuel-trim error.
