Injen Intake Issue
Discussion in 'Gen 3 Prius Accessories and Modifications' started by seoden88, Oct 4, 2018.
  1. TheChip
    TheChip Senior Member
    388
    1,210
    Misissippi
    What makes you believe you damaged it? It's a very delicate sensor, but the sensor is protected unless you go poking at it.
    James Powers likes this.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,559
    2,599
    Taylors, SC
    The MAF sensor is directional. I marked mine before disassembling the OEM system. I don't think the INJEN's mount allows it to be installed in one direction.
    It could be that it was mistakenly installed backwards.
  3. TheChip
    388
    1,210
    Misissippi
    You are correct, although if you just use one screw to secure it you could make it work. Installing it backwards would definitely cause these issues.
    Georgina Rudkus likes this.
  4. Mendel Leisk
    42,271
    Ok, sorry. Looking at the pictures, couldn't see anything.
  5. TheChip
    388
    1,210
    Misissippi
    Thought I had uploaded this previously. Red circle is where the sensor is installed on the opposite side of the pipe.
  6. seoden88
    seoden88 Junior Member
    Louisville
    I ordered s new sensor so here’s to hoping it’s just a bad sensor I should get it today hopefully that fixes it
  7. seoden88
    Louisville
    New sensor, light came back on... think PCs valve is messed up?
  8. bisco
    52,783
    try uninstalling the ingen and see what happen
    James Powers and audiodave like this.
  9. audiodave
    audiodave Active Member
    800
    272
    US
    Go back to stock and see if it's fixed as bisco mentioned.
  10. Mendel Leisk
    42,271
    Yeah, as previously mentioned: apparently the Injen allows you to install the MAF sensor in two orientations, only of which is right.
  11. seoden88
    Louisville
    I thonk before that I will replace pcv valve and try it if not I guess I’ll go back to stock but I also emailed Injen
  12. TheChip
    388
    1,210
    Misissippi
    The intake should have no reason to cause a MAF error like you're getting unless something is unplugged somewhere or it's installed wrong. If you didn't connect the intake properly you'd have a vacuum leak that may cause MAF errors.
    Hook it up to an OBD2 scanner and see exactly what's going on, and try going back to the stock setup to eliminate the possibility it's the Injen as mentioned above.
    Georgina Rudkus and Mendel Leisk like this.
  13. Georgina Rudkus
    3,559
    2,599
    Taylors, SC
    From the direction of the wire connector on the MAF sensor, it appears that the directional is correct. This is the same directional orientation in relation to the air flow that I have on the HPS.
    And, on two HPS installs on a 2012 and a 2018, I have seen no CEL issues.
  14. seoden88
    Louisville
    So went to AutoZone bought some hoses and replaced almost all vacuum hoses and bought some starting fluid and sprayed around the hoses to see if I can get a rpm rise. No to all hoses except 1. Pcv hose. As soon as I sprayed it toward engine block I got a small increase in rpm so just gonna replace pcv valve and the hose
  15. audiodave
    800
    272
    US
    Well that's definitely something that needs to be fixed. Good luck!
  16. seoden88
    Louisville
    Update. So been in contact with injen. Sent pictures data etc and waiting on them to reply. Also went to Toyota and bought a pcv valve and hose. Replaced it no issue. Reset codes and cel came back on. Waiting on injens reply then probably just go back to stock. I’ve never had issues on an intake before this is crazy.
  17. audiodave
    800
    272
    US
    It's worked without the code before?
  18. seoden88
    Louisville
    Pcv valve yes. It almost time to change it anyway. Intake no. I’ve always had CEL with it
  19. Georgina Rudkus
    3,559
    2,599
    Taylors, SC
    There is a simple easy way to check the PCV without taking it out and shaking or blowing on it.
    Remove the oil fill cap, place a rubber glove over the oil fill opening. A restricted or non-functioning PCV valve will cause the glove to inflate; indicating over pressure.
  20. seoden88
    Louisville
    That’s interesting never tried that before. Was an easy replace anyway
