Inspect very carfully before purchasing!
Discussion in 'Gen 2 Prius Main Forum' started by Toy08, Aug 7, 2008.
  1. Toy08
    Toy08 New Member
    50
    Southern Calif
    Re: 2008 Prius leans to the left
    The left to right side difference is mostly on the rear of the car, not the front. So the transaxle, motors, steering mechanism, etc would not be the main cause of this problem.
    I am going to look at the rear suspension this weekend to see what could be causing this issue. I want to see if it could be a strut, torsion bar or frame issue.
    I don't see the left lean issue on every Prius, but I have seen at least 10 in the last 3 weeks.
  2. Toy08
    Toy08 New Member
    50
    Southern Calif
    Inspect very carefully before purchasing!
    My new Prius was only 1 months old when I noticed that the car was leaning to the left side with the car completely empty. Had I noticed this before I purchased, I would have never bought the car. Now Toyota says that the ½†is within their acceptable limits and will not correct the issue. See the attached picture and let me know what you think. :confused:
    More info at the following Thread: "2008 Prius leans to the left"
    • Doc1.doc
      File size:
      599.5 KB
      488
      File size:
      59.1 KB
      1,074
  3. Platypus
    Platypus New Member
    43
    Sacramento, CA
    Could be an intentional method for dealing with the crowning of roads... no? not buying that one? :D
    I'd be interested to see if a right-hand drive also leans to the left.
    -EDIT- Had to go out and check mine and it sits dead level in relation to the ground (level concrete pad in the garage, car is level from the license plate brackets, front and rear). Perhaps the different suspension components in the touring edition help w/ the uneven weight distribution of the drive-train?
  4. Devil's Advocate
    922
    Las Vegas, Nevada
    Odd, but if it doesn't affect handling and it is only a 1/2" over the length of the car I wouldn't say that it is that out of the ordinary. I would check that 1/2" though. Maybe yours is more. It may also work itself out as the suspension settles in. Haven't heard about this before and can't imagine it is any different than what may occur in any car.
  5. cephas
    cephas Junior Member
    50
    Prius
    No, it doesn't matter, they have to fix it.
    Go to another dealer.
  6. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Why do you need to post two threads on the exact same topic in the same day? As you have already been told, the "lean" doesn't impact anything. I would go as far as to say that it's quite common. Take some deep breaths and move on. There are things in this world far more worth your energy than a little asymmetry.
  7. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    I just went out to our parking lot and surveyed the dozen or so Priuses. About 2/3 were leaning to the left and the other 1/3 were level. I did one more check and realized that the 1/3 that were level are all touring models.
  8. Tdoff1
    Tdoff1 New Member
    122
    VA
    ....now that Toyota is in NASCAR, this is done to stagger the cars and set them up for left hand turns at the super speedways.......:car:....the 2009's will be set up especially for the road courses..........:bounce:
  9. Toy08
    Toy08 New Member
    50
    Southern Calif
    Although this thread it is on the same topic as my other thread, I wanted to warn people that are about to purchase a new Prius to look closely before they close the deal. It may be easy for you to say move on, but do you have a leaner? If not, you have no room to talk. The lean is very noticeable and I shouldn’t have to put up with it. If I wanted a car that leaned, I would have bought an old car. And how do you know that the lean doesn’t impact anything, it can’t do any good in a panic right hand turn. The car only has 5K miles, what will happen when the car has 100K?
    This is the first time I have ever posted anything in a forum. For years I have read many article and found them very helpful. Your comment was not helpful. I have seen these types of responses many times, why do people insist on belittling other peoples concerns? Are you a Toyota Rep?
  10. Toy08
    Toy08 New Member
    50
    Southern Calif
    Read my other post: "2008 Prius leans to the left" There are many other Prius’s out there that have the same issue. My car only has 5K miles, would you expect this to happen to any other car so soon? The only other vehicles I see on the road that have issues like this are pickups that have been used for off-road.
  11. penbed
    penbed New Member
    222
    USA-Arkansas
    Oops-just lost my vote for post of the month.
    (The first post)
  12. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi All,
    The Prius does lean to the left, due to the weight of MG2. In Japan, the driver is on the right. So its less of an issue.
    If you experience any handlinq quirks related to it, just pump of the left front tire a PSI or 2 more.
  13. Toy08
    Toy08 New Member
    50
    Southern Calif
    My wife said that she hadn’t noticed the issue on any higher end models, I guess this meant touring models.
    This is very interesting. I will have to see what suspension parts are different on the touring model. Maybe I can upgrade a strut or torsion bar to get rid of the issue.
    Thanks for the observation. :)
  14. Toy08
    Toy08 New Member
    50
    Southern Calif
    We have noticed that this leaning issue does not appear on the touring models. Any ideas why?
  15. Toy08
    Toy08 New Member
    50
    Southern Calif
    The touring model does not seem to have the same issue. Several others have noticed the same thing.
  16. Patrick Wong
    18,210
    6,517
    The following string provides info on installing Touring suspension parts on non-Touring. However it does not appear to show required part numbers.
    http://priuschat.com/forums/prius-main-forum/41925-touring-suspension-parts-research-5.html
    See post #50 of that string and take a look at the last picture in that post. It's not clear whether the two old springs have an identical height or not... Maybe this is why the non-Touring Prius tends to sag on one side.
  17. Toy08
    Toy08 New Member
    50
    Southern Calif
    Thank you
  18. PriuStorm
    PriuStorm Senior Member
    2,239
    149
    Davis, CA
    Here's a theory.... people already noted that if a person sits in the passenger seat, the car evens out. Well, in the country of origin of the Prius, Japan, the driver sits on that side! Maybe it was done on purpose, and the Japanese are achieving higher mpg because their cars drive more level!
  19. Ichiro
    Ichiro Member
    335
    SF
    dude, why don't you post the picture directly. attaching it in a word document is annoyingly stupid.
  20. Ichiro
    Ichiro Member
    335
    SF
    why don't you sell your Prius now? It's obviously a big problem for you, and I am certain that you won't have any difficulty getting a good price for it, in spite of it.
