Inspection (emissions) failed. What to do?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Vlad, Nov 13, 2007.
  1. jk450
    jk450 New Member
    <div class='quotetop'>QUOTE(Rob Smith @ Nov 13 2007, 05:43 PM) [snapback]539070[/snapback]</div>
    That doesn't always happen.
    Many states test emissions. Many query the OBD system records, AND test emissions.
    An inoperative MIL is itself cause to fail the test, but the cluster will have to be pulled to replace the lamp before the test is repeated. And a code is a starting point, not a diagnosis.
    That may be the charge for the state-mandated test, which is performed on a $35,000-$50,000 machine. The machine also has significant maintenance costs, which can easily be hundreds of dollars per month. Many shops lose money on these programs - but the consumer won't care about that.
    Most dealerships set this charge high to discourage walk-in traffic. They just need to be able to test their used-car inventory.
    That depends on the cost of the component at time of manufacture. Some are covered, some aren't.
    Kinda :)
  2. Vlad
    Vlad Junior Member
    Here's the resolution. I took it to another place and the mechanic confirmed the inspection failure and that something electrical was wrong in the OBD, in that it wasn't providing the specific code for the failure. He suggested I drive around for 50-100 miles and bring it back. So my wife and I went on a nice fall foliage drive, brought it back, and the car passed!
    Vlad
  3. jk450
    jk450 New Member
    <div class='quotetop'>QUOTE(Vlad @ Nov 17 2007, 06:48 PM) [snapback]541036[/snapback]</div>
    An odd explanation. It sounds more likely that - rather than something "electrical" being wrong with the "OBD", one of the on-board monitors - periodic diagnostic self-tests, which are executed via software - had not yet run. My guess would be either the EVAP monitor or the catalyst monitor.
    It's rare for Toyotas to have a problem running monitors. For other makes, it's quite common.
  4. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Don't the mode $06 monitors have to at least show "complete" for an
    emissions check to be valid? Or is some of that data translated
    into mode $01 PIDs for the sake of the mandated OBDII stuff? If
    you've got a good reference or two on how all this plays out, I
    wouldn't mind brushing up..
    _H*
  5. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    612
    23
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Nov 14 2007, 02:21 AM) [snapback]539349[/snapback]</div>
    The OP has a 2002 Prius, which is rated as SULEV and has an 8-year/100,000-mile battery/emissions warranty. The 10-year/150,000-mile warranty is for the AT-PZEV Gen II Prius.
