Instability on highway
Discussion in 'Prime Main Forum (2017-2022)' started by Emro, Jun 10, 2017.
  1. Emro
    Emro New Member
    SoCal
    Hello All,
    I'm a new Prius Prime owner and been driving now for two weeks and overall experience with the Prime has been great. My work is 120 miles round trip so I'm truly fascinated with the gas savings I'm getting. My trip is mostly highways but one thing I've noticed with the car on certain California highways (91 east bound) the car sways to left and right depending on certain area of the highways with more prominent grooves on the road. The stock tire it came with is Bridgestone Ecosave, not sure if it is the tire causing this instability, I've also turned off LDA thinking it might be doing something. The dealer is willing to let me use another Prime to see if I'll get the same behavior with loaner but, has anyone from Socal with Prime experienced this?
    Thanks in advance with your reply.
    HPrimeAdvanced likes this.
  2. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    No, not at all.
  3. alexcue
    alexcue Active Member
    346
    311
    So Cal
    More than likely it's the tires, first time I got the 2014 Prius I felt like I was wandering around the road on the rain grooves. My Tundra never has done that, though I've felt that sensation on the Harley on some highways. That's not a good feeling.
    Anyway my Prime is much better IMO than the old car, in all honesty I just got used to it. I'm pretty sure the LDA had nothing to do with it. Personally I did lower the sensitivity of the LDA, but that's another story.
  4. Emro
    Emro New Member
    SoCal
    Thanks...
  5. Emro
    Emro New Member
    SoCal
    I'm suspecting it's the tires too. Was wondering if decreasing the tire pressure might help. Thanks for your reply.
  6. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    When I got my car from the dealer, the tire were at 50psi.
    You might want to check yours.
    jp
    PT Guy likes this.
  7. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    haven't noticed anything either, have taken mine up to 105 and was surprised how well it did ... I have the Toyos set at 42/41.
    I took the 91 west going from Temecula to LAX when I had the car for a week or 2, again, didn't notice anything unusual
  8. Trollbait
    12,776
    May just be the tires, but it is possible for the alignment to get knocked out of spec during shipping. It could also be in spec, but with less toe in than you are use too. That increases cruising efficiency, but can increase wandering, squirrelliness, etc. while going straight at speed. The road grooves just exacerbate whatever it is.
  9. fuzzy1
    10,652
  10. bwilson4web
    16,480
    On my Prius Prime Plus, there is too much negative camber on the rear wheels and the passenger front. In theory, negative camber helps on taking curves BUT I suspect it can also couple with the road to induce a side-to-side 'hunting.' Unfortunately, Toyota won't help in correcting the negative camber.
    HPrimeAdvanced and alexcue like this.
  11. White 17
    White 17 Junior Member
    59
    17
    Nor Cal
    I have noticed it also. I am thinking it is the alignment as was noted above.
    Anyone gotten Toyota to do an alignment under warranty?
  12. Trollbait
    12,776
    That is the likely cause, but the degree can vary upon tires, alignment, and car model.
    IIRC, our gen2 was worse than other cars on the same road.
    I say have the dealer check the alignment after checking the tire pressure.
    #12 Trollbait, Jun 11, 2017
  13. bwilson4web
    16,480
    When you go to the dealer, say something like:
    "I was driving the other night when I hit a massive <pot hole | tree limb | truck tire tread> and ever since, the car has been squirrelly trying to drift off to the road. Please check the alignment and give me a copy of the result. If the printer is down, I'll be happy to take a photo with my cell phone. I need to show it to my <wife | husband | Dad>"​
  14. Emro
    Emro New Member
    SoCal
    Thanks but, 91 east bound is where most noticeable at any speed.
  15. Emro
    Emro New Member
    SoCal
    Can camber be adjusted on these cars?
  16. bwilson4web
    16,480
    Yes but it isn't easy. I'm using shim tabs on the rear and will be adjusting the front camber bolt next. Worse comes to worse, I can replace the camber bolt with one that allows a greater range.
  17. White 17
    59
    17
    Nor Cal
    Have you adjusted the toe already? What is the recommended settings for our cars?
  18. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    No such wandering problem with our Toyo tires. Do check your cold inflation pressure. The sticker on the door jam has the correct pressures (do I remember right...36 front & 35 rear?) Some tires on some pavement will just follow the grooves--can't be helped.
    If the alignment was off from delivery, then it is a pre-delivery set up problem. That should be the dealership's responsibility. If I told the shop that I hit a pot hole or something and knocked the alignment out, then it would be my responsibility. The only time I think alignment would be a warranty claim would be if suspension parts were replaced under warranty where the replacement work changed the alignment adjusters.
  19. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    This happens in my gen 2 Prius, especially, but in the gen 4, the Toyos are very unstable IMO. Maybe you aren't used to the thin tires of the Prime compared to your old car. My gen 4 pulls left and right more often in construction zones and on the 405 around Irvine.
  20. bwilson4web
    16,480
    We owned a 2003 Prius between 2005-2016. During that time, I eventually solved the neutral stability that cause the car to not tract a true line. I solved the problem by replacing the front tires with over-sized tires, fires to correct the speedometer/tripmeter error and later as a type of poor-man overdrive. Larger diameter and heavier tires, they also increased the wheel gyroscopic stability. The effect was quite dramatic when I first stumbled across it.
    I drove up to Hybridfest one year with a pair of 'true sized' tires on the rear and the a pair of recommended front tires. The car handled like when I first got it, drive it every second and no distractions. At Hybridfest Sunday morning, I swapped the front and back and the handling definitely improved:
    This is a photo before I started my poor-man overdrive test, the tire in the middle. Notice the front tire is larger than the rear and this was the first change that improved stability. It also brought the speedometer and tripmeters into true values.
