Instability on highway
Discussion in 'Prime Main Forum (2017-2022)' started by Emro, Jun 10, 2017.
  1. Emro
    Emro New Member
    SoCal
    Thanks to all who replied and have given their opinions, experiences and suggestions, I truly welcome them.
    I want to give an update after the dealer had given me an identical car to test last Tuesday. As I suspect, the instability is still there, exactly the same behavior as the one I own. The following morning before driving to work, I checked the tire pressure, it is set at a whopping 48 psi on all 4 corners. Recommended is 36f/35r so I set the pressure at 35f/34r and what a big difference. Though there is still some presence of tramlining, it is totally acceptable to me and I believe it is just in the nature of those mickey mouse tires causing the instability. Anyway, seems like I just have to live with it at the moment and may look at other tires when it's time to change. Also, one of our forum member have installed this chasis brace called Cusco and he's happy with it. Might also look at this option since it's not that expensive. Again thanks to all, be safe and God Bless you all.
    -emro
    HPrimeAdvanced likes this.
    52,762
    congrats, all the best!(y)
  3. Mendel Leisk
    42,250
    Your saying the trip meter (and hence the odometer?) were off with the stock tires? (n)
  4. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Cusco web site shows parts for Gen 3 Prius, not the Gen 4 chassis.
    CUSCO USA
    Expect any chassis or strut tower brace to stiffen the feel of the car. Some amount of chassis flex is expected and allowed for in the design.
  5. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    I think that phenomenom you describe is called "hunting", it's when the car's tires grab for the grooves in the road.
    My Honda Insight Coupe hybrid did that to a ridiculous extreme. It would seem that the car could change lanes by itself. It was particularly noticeable at higher speeds. I experimented with a different set of tires and got a complete fix of this problem, however, the fuel economy went way down. The problem tires were also Bridgestones. I've had no such problem when I switched to the Michelin low-rolling-resistance tires, and the fuel economy, noise level, durability, and ride quality were all excellent (2012 Prius Plug-in).
  6. mistermojorizin
    mistermojorizin Active Member
    310
    137
    usa
    2019 Prius Prime
    What do you mean by over-sized tires? Bigger rim/tire combo or bigger diameter on the stock rim? Any recommendations for the Prime? Also, is it the increased mass or just the increased diameter that fixes it? Or stiffness/tire compound? Thanks for any help.
  7. bwilson4web
    16,512
    I used the "rev/mile" as the true diameter metric on the stock rims. Not as easy today, Tire Rack still lists the specifications on their web site on a tire/tire basis. I just cut-and-paste into a spreadsheet.
    I no longer own a Prime so I'd prefer not to speculate. My own cars, no problem, but I'm over a year away from our Prime and it was traded-in with the OEM tires.
    The goal is to seek a larger polar moment of inertia. Even slightly larger diameter (i.e., lower revs/mile) has a much greater effect than weight. BTW, I recommend doing a pair of new tires at a time. That way you can check clearance in the rear and dynamic effects by moving them to the front. If the first pair work, get the second pair and have a happy.
    GOOD LUCK!
    mistermojorizin likes this.
  8. PianoBench
    PianoBench Member
    155
    95
    San Francisco
    Toyota does sell a legitimate motion control beam for both the front and rear of the vehicle. I believe it will stiffen the body roll and thus stability on our vehicles.
    Source:
    Toyota TRD JP
    PRIUS PHV -FEATURE- | TRD
    Action:
    I want to add something to the original discussion. Both my 2016 Toyota Prius and then 2017 Toyota Prius Prime drove straight and super stable on the freeways. Very rarely do they go off track on non windy days on a clear stretch of flat smooth road. This is because I very carefully avoid ALL potholes and generally try my best to route around broken roads. I have driven many cars and many new cars in the past and even sports cars with stiff suspensions. And they all had one thing in common. Stiff suspension + bad roads will equal drift or highway instabilities.
    Anyway take my advice with a grain of salt! For certain if you upgrade the stock 195 mm tires to something say 205 or 225 mm, your vehicle should in theory be more stable and drive straight.
    mistermojorizin and bwilson4web like this.
  9. PT Guy
    1,085
    713
    Just a reminder, when the cars are shipped from the factory the tires are inflated hard. This is to reduce the bounce while they're lashed to the deck inside the car carrier ship for the times the ship encounters rough weather. The generally worthless pre-delivery inspection by the dealership is supposed to correct the tire inflation pressures back to what is shown on the placard on the driver's door jam. Supposed to....
    Groove wandering and tramlining, mentioned above, are real things. Different model tires will have different groove-wandering characteristics. While Bridgestone makes many fine tire models (I've heard very good things about the Bridgestone Turanza QuietTrack), is anyone pleased with the original equipment Bridgestone tires Toyota chose for the Prime?
  10. PianoBench
    PianoBench Member
    155
    95
    San Francisco
    I just noticed that this thread had been dead for the past 3 years....
    Until user HPrimeAdvanced brought it back from the grave!!!
  11. Ital
    Ital New Member
    CT
    2022 Prius Prime
    Cusco now does carry the rear sway bar for the 2022 prius prime. I am debating between this or the MEG stabilizer bars
    • Solid 24mm +50% (2WD)
    PRODUCT INFO
    MSRP
    $ 347.00
    Part No.
    1A1 311 B24
    That is from Cusco's website
