Install euro Prius+ battery pack into U.S. Prius V?
Discussion in 'Prius v Accessories and Modifications' started by MPGPrius, Jul 19, 2022.
  1. MPGPrius
    MPGPrius New Member
    Install euro Prius+ battery pack into U.S. Prius V? Im interested in buying a Prius V in the U.S. to replace my minivan. But I need deeper cargo room in the rear to carry the bigger cargo I use. So I want to replace the rear mounted battery pack, with the center console battery pack from the European Prius+. Does anyone know if this is possible? Im hopping its plug and play, because they the two cars are so similar.
    Even better, can the rear mounted battery pack, be mounted in between the front seats on its side, if it will fit? Im aware Id have to extend the electrical cables and bolt down custom brackets to mount it, if so. Thanks
    #1 MPGPrius, Jul 19, 2022
  2. Tombukt2
    Tombukt2 Senior Member
    9,173
    1,609
    Durham NC
    I bet you could move it anywhere you wanted to you would just need to extend the cabling and come up with mounting points or the bracketry from the European car or what it looks like so you can fab it up here kind of like the side brackets on the Gen 2 battery I don't know what the setup looks like in a v. But it's doable but you'll probably be extending some of those orange cables.
    49,508
    doesn't sound safe
