Installation FIAMM EL GRANDE 74100 HORN Gen 4 Prius + VID SOUND
Discussion in 'Gen 4 Prius Accessories and Modifications' started by NguyenCB7, Sep 4, 2016.
Tags:
  1. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    There's a guy in an old Cadillac, drives by my house 3 times a week. He has a "Train Horn" on that car. He must be signaling someone around here because he always blows it! And every time I hear it, I jump.:eek:
    But I'm ok with it. I grew up in a house that had a rail-road crossing right behind it. EVERY DAY, loud bells and train horns. :)
  2. Coast Cruiser
    2,267
    2,571
    FIAMM horns arrived today, and installation complete. It is LOUD! Much better.
    BUT... here's my gripes. :LOL:
    I could barely get my hands/wrists in there! Took me over an hour. Cussing all the way...
    Needed a 12 mm socket or wrench to get the nut off the factory horn bracket. (10 mm to tighten the FIAMM nut).
    Horns did not fit in the space, if using the stock factory brackets. I tried every which way but loose! How the heck did you fit them in there?! I tried facing front, facing back, upside down... I finally had to remove the stock brackets, and use the FIAMM bracelets supplied. Then it was easy.
    The factory plug does not attach all that good to the FIAMM horn connector. It slides on, but it didn't "click on" like it did to the factory horn.
    And last, how do I get the clips to SNAP back into the plastic cover? The cover is on correctly, but the clips are kinda loose.
    Thanks.
    RCO and krmcg like this.
  3. krmcg
    2,592
    2,388
    Whittier, CA
    Good for you.
    the clips are closed when flush along the top. Pushing the center beyond flush loosens them. I used the stock brackets, just needed the supplied nuts. One caution that I listened to was to make sure the openings of the new horns pointed down, so that no water could get trapped in them. If it were to rain in SoCal.
    RCO likes this.
  4. Coast Cruiser
    2,267
    2,571
    Thanks Kevin. My clips are flush, but still loose. They didn't seem to snap back in very good. I'll check again. And yes, I have the horn funnel(?) facing down... almost. :D I had to turn it a certain way in order for the plug to attach.
    And how on God's Green Earth did you fit the horns in there using the stock brackets?!?!?!??? I tried in front of the bracket, behind the bracket.... every way. If they are installed correctly, which way is the red cover facing? Towards the engine, or towards the front grill? (Don't laugh.)
    RCO likes this.
  5. krmcg
    2,592
    2,388
    Whittier, CA
    I wish I could remember. And now I don't want to take my clips out again to see - they may not re-install well.
    RCO likes this.
  6. Coast Cruiser
    2,267
    2,571
    Yeah, I wish they were small threaded screws. That plastic is cheap. I got them back in, but they are not as tight as before. You have to "unlock" it, put it in the hole, and then gently press the center button back down.
    And one of mine is missing. I don't think it was there to begin with. I have an extra hole. I wonder if the dealer lost it during the inspection and oil change.
    RCO likes this.
  7. NguyenCB7
    NguyenCB7 Member
    71
    67
    Fullerton,ca
    It should fit fine. I didn't have much trouble and thats weird that you had to use a 12mm. I only used a 10mm. I need to turn the open downwards hahaha. Thanks for the advice.
    RCO, Coast Cruiser and krmcg like this.
  8. krmcg
    2,592
    2,388
    Whittier, CA
    I bought some extras from the dealer. $3.00 bucks a piece.
    RCO likes this.
  9. NguyenCB7
    NguyenCB7 Member
    71
    67
    Fullerton,ca
    RCO and Coast Cruiser like this.
  10. NguyenCB7
    NguyenCB7 Member
    71
    67
    Fullerton,ca
    Red cover facing engine
    Coast Cruiser likes this.
  11. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    I do think I'm gonna have to pick up a set of these here horns for my ride :)
    How much louder than stock are they would you estimate? Worth while upgrade? Thx.
    Jacuna and RCO like this.
  12. NguyenCB7
    NguyenCB7 Member
    71
    67
    Fullerton,ca
    I think they are big upgrade compared to a compact beep beep. It sounds like a Chevy Suburban instead of a Prius.
  13. krmcg
    2,592
    2,388
    Whittier, CA
    Like a duckling turned into a duck
  14. NguyenCB7
    NguyenCB7 Member
    71
    67
    Fullerton,ca
    LOL way better analogy than mine
  15. Coast Cruiser
    2,267
    2,571
    Order from Cerritos?
  16. krmcg
    2,592
    2,388
    Whittier, CA
    Norwalk Toyota. They had them in stock.
  17. Coast Cruiser
    2,267
    2,571
    Thanks much. Sure is a weird thing to have in stock, isn't it?
  18. krmcg
    2,592
    2,388
    Whittier, CA
    I was pleasantly surprised. But $3.00 for a .10 cent item, why not?
    RCO likes this.
  19. Coast Cruiser
    2,267
    2,571
    My whole plastic piece is loose now. Those clips suck! I tried to find a short, fat, big-headed screw to self tap into that hole....
  20. Coast Cruiser
    2,267
    2,571
    How do you think it would get wet from rain? I'm more concerned when I wash the car, and spray water towards the grill.
    It's a great sounding horn. Like a Cadillac! :LOL: Thanks for recommending it. One last dumb question... Does it matter which one goes on the right, and which on the left?
    RCO likes this.
