Installation FIAMM EL GRANDE 74100 HORN Gen 4 Prius + VID SOUND
Discussion in 'Gen 4 Prius Accessories and Modifications' started by NguyenCB7, Sep 4, 2016.
Tags:
  1. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    I see it now. In a past lifetime I traveled the country for Fedex. I forget the exact name but just up the road in Ventura is a fish place on Seaward Avenue that was really good and interestingly had who knows how many hundreds of dollar bills stuck to the ceiling with customer comments on them. Farther up in Buellton was Pea Soup Andersen's, my other favorite place to eat out there.
  2. RCE1
    RCE1 Member
    70
    71
    Northern California
    Four Touring
    I did the Fiamm El Grande horn installation. Very pleasing results, although I did manage to lose the first "clip" I removed. Went right to the bottom of the engine compartment. Hope it doesn't cause a fire or hurt my mileage or anything...
    Anyway, the passenger side was a bit difficult. I had some wiring in the way I didn't really want to unclip, so I had to work around it. Also, the 10mm factory fastener on the Denso horn felt like it was staked in there or something. Very hard to get it off, but perseverance and pliers won out. The driver's side was no problem at all. I used the factory brackets and the Fiamm fasteners. My local dealer gave me the clips for $1.21 and the parts department is open till 4pm (that's 16:00 to all you 24 hour types) on Saturday.
    I'd recommend the upgrade to anyone.
    xliderider, NguyenCB7 and krmcg like this.
  3. krmcg
    2,592
    2,392
    Whittier, CA
    Well done. Way to stick to it.
  4. Jorge L
    Jorge L Junior Member
    Mexico City
    Last weekend I installed the El Grande 74100 horns.
    Installation was a bit tougher than I was expecting, I had to remove the factory brackets because I couldn't remove the factory horns from them. My factory horns were not Denso, they were Maruko, the screws that this model uses are really hard to remove.
    So I just used the brackets that came with the FIAMM horns. I'm happy with the results, Thanks for posting the instructions.
  5. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    I STILL have cuts on my wrists. Which one of you guys told me to install new horns??? :ROFLMAO:
    But, I like them. When I honk, the sound reminds me of the 1982 Oldsmobile Cutlass I had!!
    NguyenCB7, RCO and xliderider like this.
  6. MichelleStone
    MichelleStone Senior Member
    549
    818
    Mariposa, CA
    I'd love to replace the squeak toot with a HONK HONK. But I've had my car for five weeks now and the only time I've used the horn was to make sure it's in working order. It surprised the heck out of my dog.
    RCO likes this.
  7. Coast Cruiser
    2,267
    2,571
    I actually had to use my new horns for real, this morning. A little Geo Metro(?) coming out of a gas station attempted to pull right out in front of me. How can you NOT see a bright WHITE car coming, with bright LED lights! I missed her by about 3 feet. HONK! HONK! HONK! Olds Cutlass coming.... :eek::ROFLMAO:
    RCO and krmcg like this.
  8. NguyenCB7
    NguyenCB7 Member
    71
    67
    Fullerton,ca
    I wonder why they are different.
  9. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Deleted, ignore.
  10. Terre
    Terre New Member
    Easton
    That is a much better sounding horn. Thank you, great program you put out here for those wanting a different sounding horn. I just purchase a 2017 Prius (trim level 2) and I want a different horn than stock. Thank you for this post!
    NguyenCB7 likes this.
  11. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    Well I finally got around to upgrading my horns.... no more meep meep for me.
    After recommendation and instruction from this post I ordered a pair of "FIAMM 74100 El Grande" horns and wow what a difference and as stated, truly plug and play.
    Only took 30 minutes, most of that time was trying to get them positioned with enough of a downward turn to stop any water ingress. The wiring is quite tight and I didn't want to start cutting any ties to give a bit more slack. I am happy that they are going to be ok as it all seemed pretty clean an dry in that area anyway. I also had to fit them with the red facing out due to the wiring loom being so tight.
    I used the original brackets that the Maruko horns were attached too which is good as removing the factory brackets looked as though it would be a bit tricky.
    Ordered direct from Amazon.com for the brilliant price of £25.38 and due to its price there was no worry about duty as import fees are calculated at the check out.
    I have put links to before and after below... [​IMG]
    Before
    After
    emmbec, krmcg and RCO like this.
  12. 228Prius
    228Prius New Member
    Gulf Coast, MS
    2022 Prius
    Resurrecting an old thread. Bought the Fiamm El Grandes, install was a breeze, but no horn after installation on my 2022. I had to use the included grounding straps that the Fiamm setup came with.
  13. jw_teacher
    jw_teacher Junior Member
    87
    MO
    2018 Prius Prime
    I plan on finally changing the horn in my car next month. Should I wear thick gloves for protection from potential electric shock when plugging and unplugging the wire? Sorry if it is a dumb question. I've had a bad experience with electric shock in the past!
    EDIT: Also, I tried pushing in the clips to unlock the top cover but nothing happens. I'm sure I'm missing something.
    #73 jw_teacher, Sep 6, 2023
  14. Harters
    335
    427
    UK
    Excel
    No risk of electric shock when I changed mine. The clips do not push in, the smaller centre piece partially pulls out, this then releases the tension on the fitting and it pulls out as one piece.
    jw_teacher likes this.
  15. jw_teacher
    87
    MO
    2018 Prius Prime
    Thank you! I will try again soon.
    Harters likes this.
  16. Drakxyfly
    Drakxyfly Member
    119
    26
    Usa
    2021 Prius
    Is there a difference version i cant find? I only found this version with a replay included and pos/neg terminals
  17. Drakxyfly
    Drakxyfly Member
    119
    26
    Usa
    2021 Prius
