Installed 5-spoke 17" oem Rav4 wheels
Discussion in 'Prius v Accessories and Modifications' started by Centerpunch, Oct 18, 2019.
  1. Centerpunch
    Centerpunch Active Member
    151
    141
    OH / NC
    2017 Prius v wagon
    Bought a set of 17x7 oem Rav4 take-off wheels on ebay, added a set of Michelin Cross Climate+ tires in slightly bigger 225-50-17 from Tire Rack, just had them installed. I like 'em!
    GregC1979, Garandman, icyrius and 4 others like this.
  2. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    We like that slightly larger diameter (and section width) tire size. Matches up the speedo with GPS indicated road speed.
  3. Centerpunch
    151
    141
    OH / NC
    2017 Prius v wagon
    I'm new here- it was reading your posts that led me in this direction.
    A few other minor aesthetic mods coming soon (Valenti tail lights, body-color background behind T emblems, dual exhaust tip, replacing rear Prius emblem with something else), plus I'm also considering doing matte black vinyl on the lowest part of the car, to make the car look less tall and boxy.
    Air_Boss likes this.
  4. Mendel Leisk
    42,343
    Would the Rav4 rims work with the stock Prius v tire size? (I'm guessing yes.) I think there's a Camry rim that also works?
    Always interesting to learn about rim cross-politicization, doubly so when the stock rims have plastic wheel covers.
  5. Centerpunch
    151
    141
    OH / NC
    2017 Prius v wagon
    Well, if you don't like the plastic wheels covers, you can just take them off and show off the aluminum wheels underneath them, although you'll need to pick up some centercaps.
    Pretty sure most late-model 5-lug Toyota wheels for the larger cars should fit. I think the oem Prius v 5 wheel is 17x7 with 39mm offset, and the wheels I bought are exactly the same.
    NOTE: Normal Prius, Prius C and Corolla use smaller 5x100 bolt circle, so those won't fit our cars.
    Our bolt circle is 4.5" x 5, also called 114.3(mm) x 5 (although some online sellers round that to 114 or 115).
    I think the original Prius v wheel offset is 39mm, that determines the relationship between the the wheel and the car's mounting surface, i.e., how far the wheel sticks out. As long as you are within a few mm, you should be fine. (6mm is about 1/4 inch).
    Most oem wheels will have the dimensions and offset cast or stamped into the wheel, usually on the back. As an example, here are the wheels I bought TOYOTA RAV4 17" WHEELS HYPER SILVER STOCK OEM FACTORY RIMS 17 RAV-4 CAMRY SIENNA | eBay , and below I've attached a photo of those dimensions cast on my wheels.
    Other makes also use the same bolt pattern and similar offset (including lots of Hondas, Kias, Hyundais, Nissans, and even some Fords, although most of the Fords have the wrong offset), but if you're looking at wheels from another make you also have to make sure the center hole in the wheel is compatible, I think ours are 60.1 mm. If the wheels you buy have larger centerbore, you can buy adapters for our cars, but (obviously) if the centerbore is smaller, the wheels just won't fit.
    I found this online, but haven't confirmed the info (this shows bolt pattern and centerbore size, but you'd still have to make sure the offset was close to 39mm):
    Honda 5x114.3 CB64.1
    Toyota 5x114.3 CB60.1
    Nissan 5x114.3 CB66.1
    Mustang 5x114.3 CB70.5
    Subaru 5x114.3 CB56.1
    That's a good reason to stick to Toyota wheels unless you can test mount the wheels before you buy them.
    #5 Centerpunch, Oct 18, 2019
    GregC1979, jzchen and Mendel Leisk like this.
  6. Centerpunch
    151
    141
    OH / NC
    2017 Prius v wagon
    Looking at some wheels on ebay, I see that some Toyota wheels have an offset of 50mm, which would move the wheels inward 11mm (7/16"), which is probably a bigger change than I'd recommend- might rub, and certainly would change the steering characteristics a bit.
  7. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Wheel offset is all part of the manufactures "Recipe", meaning it is also dependent on wheel width.
    Don't think of it as just one static number, because it's not.
    Rob43
  8. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    I had old 17 inch OEM alloy wheels that came off from our Sienna. It had the same bolt pattern as our new Nissan, but the center bore size was incompatible. I was hoping to use them as winter wheels but did not fit. I ended up listing them on local classifieds. A guy bought them for his RAV4 and was very happy. RAV4 17 inch wheels and Sienna 17 inch wheels had exactly the same spec.
  9. Centerpunch
    151
    141
    OH / NC
    2017 Prius v wagon
    I would actually say that offset is independent of wheel width. As I'm sure you know, it is the distance from the center of the wheel to the mounting surface of the hub. https://www.tirerack.com/wheels/tech/techpage.jsp?techid=101
    The suspension and steering geometry of a car is designed for a certain offset wheel.
    For a given offset, the backspacing will obviously vary for wheels of different widths.
    But for proper steering characteristics, the offset should ideally stay close to the original.
    In any case, I think in the case of our Prius wagons we are usually talking about wheels the same width as the originals.
    For folks new to these concepts, our cars have wheels like the one shown on the left in this image, with a positive offset of 39mm (about 1.5")
  10. Centerpunch
    151
    141
    OH / NC
    2017 Prius v wagon
    Makes sense. Your Sienna wheels had a 60.1mm hole, so they wouldn't fit over the 66.1mm hub of the Nissan.
    Salamander_King likes this.
  11. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    LOL,
    You're talking to someone that has the only Wheel Fitment Sticky thread on this forum.
    Rob43
    #11 Rob43, Oct 18, 2019
  12. Centerpunch
    151
    141
    OH / NC
    2017 Prius v wagon
    LOL right back atcha! Not sure what that's about, tho.
    I'm certainly new here, but Mendel asked a question or two, and I tried to answer it in a clear way, that's all. Not trying to step on anyone's toes.
    #12 Centerpunch, Oct 18, 2019
  13. JimInRadfordVA
    JimInRadfordVA Junior Member
    Radford, VA
    If the centerbore is too small, you can use a router with a carbide bit to enlarge it to the correct dimension. Used to do this to make Cadillac Escalade wheels fit an early Dodge D50/Mitsubishi Might Max
  14. Centerpunch
    151
    141
    OH / NC
    2017 Prius v wagon
    That’s probably fine for older vehicles like your Dodge/Mitsu, but newer cars use “hubcentric” wheels where the wheel is centered on the hub by a precise fit of the centerbore onto the hub.
    https://blog.tirerack.com/blog/turk-t/hub-centric-vs-lug-centric-wheel-fitments
  15. rice247
    rice247 Junior Member
    Here
    those wheels look good on the V!
    GregC1979, ETAV8R and Centerpunch like this.
  16. ozjimjam
    ozjimjam Junior Member
    35
    17
    22
    australia
    2016 Prius v wagon
    Thanks, I almost bought some Nissan alloys, completely overlooked the CB
  17. ETAV8R
    ETAV8R New Member
    Republic of Kommiefornia
    2015 Prius v wagon
    New here and going to revive this thread. Those wheels look really good on the V. I'd like something similar in a 16" option to have more rubber than rim.
