Installed a 1.5 in lift kit today
Discussion in 'Gen 3 Prius Accessories and Modifications' started by douglasjre, Sep 24, 2022.
  1. douglasjre
    douglasjre Senior Member
    2,249
    751
    Null, NL
    ...And put in new shocks struts sway bar links sway bar bushings shock socks and end stops while I was there. Total cost in parts was about $1,000. Did an oil change with a Toyota OEM filter for him while I was there. Customer chose the upgraded rear springs and painted the front springs to match.
    I can't believe how good this car rides now. I want to do it to mine....
  2. lech auto air conditionin
    830
    606
    261
    san francisco
    I really want one of these kits I’ve been eyeing this since I use my vehicle 2012 Prius C as a work truck as you know if you seen any of my post
    I want to put some really stiff racing struts all the way around don’t care about the smooth ride since I sometimes travel with as much as 1000 pounds on my roof rack a little bit top-heavy. I always have 800+ pounds of tools equipment and supplies in the vehicle
    and every now and then carry a trailer with 700 to 1200 pounds pushed it one time to 2000 pounds won’t do that again. (it was just a short trip about 20 blocks in an industrial area Backstreets 25 mph and under)
    douglasjre and WesleyRiccipio like this.
  3. douglasjre
    2,249
    751
    Null, NL
    KYB Excel g is far better than Sachs. I haven't tried bilstein's yet. Do you know which Bilstein makes that would fit?
  4. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    410
    2013 Prius Plug-in
