Installed kit from Plug in Supply getting 28 miles!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jim335, Oct 6, 2012.
  1. jim335
    jim335 Member
    100
    50
    pa
    It seems to, but I have just started using the add on, so I will have to see if I run out or ev range much. I do a lot more driving than just a commute. About 2500 miles per month.
    John Hatchett likes this.
  2. jim335
    jim335 Member
    100
    50
    pa
    The pip battery is4.4 kwh but only uses about 2.7 to 3 kwh for the ev part of driving and saves the rest for hybrid, so the usable size of the add-on is larger.+
    52,809
    that's why i asked the question re useful kw of pis battery.
    52,809
    gotcha. so the actual size of the add on is 4kwh?
  5. jim335
    jim335 Member
    100
    50
    pa
    The plug in supply website is not updated because Robb is out of town until almost the end of the month. He stated he will update when he gets back.
  6. bisco
    52,809
  7. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Please do.
    " Anyway, I had no time to stop at all and I hit them. All my groceries (I was just coming back from the store) flew forward and exploded out of their bags AND packaging."
  8. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
    can some1 explain the method of upload images to pc . I just do not get how to post on PC and I have Flickr acct
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  10. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    don't download them when you're finished setting max file size, save them to disk
  11. NortTexSalv04Prius
    915
    116
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    lemme try one heah: 9-4-2012 EXCEL EXPANDED CHARTS WITH KWH DISPLAYED.JPG
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  14. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Does this mean the additional battery charger is optional? Did you ever have a chance to charge the add-on pack with the built-in battery charger? How does it work (does it charge the OEM or add-on pack first, or both at the same time)? How long does it take?
    Thanks in advance.
  15. vinhboy
    vinhboy Junior Member
    25
    Davis, CA
    This thread is getting really big and off topic. Did I miss the promised pictures? Or has the OP not delivered yet? Thanks.
  16. slcMPG
    slcMPG Member
    221
    65
    SLC, Utah
    Back at post 129
    vinhboy likes this.
  17. jim335
    jim335 Member
    100
    50
    pa
    The additional battery charger is not optional. It is part of the total cost of the diy kit. You need to use the separate charger because the built in charger will not handle 2 batteries in parallel. I just plug the car into my level II home charger and the additional charger into a heavy 12 gauge extension cord. The cord goes in thru the rear hatch which will close to the first click of the latch, not all the way tight, but car is all closed up. In 1.5 hrs I can go 14 to 18 miles or in 3 hrs I can go 21 to 28 miles, depending on driving conditions. For short local trips, less than 12 miles round trip I just use the factory pack. When I come back, I charge up again, the factory pack is ready again in 1.5 hrs. and the add-on is then fully charged. first 1.5 hrs and second 1.5 hrs, since it was not used for short trip. Then it is ready for up to 28 mile trip.
  18. bisco
    52,809
    have yo completed the permanent install jim?
  19. jim335
    jim335 Member
    100
    50
    pa
    Not quite, I am using it every day, still working great. I haven't made my final decision where I will put the board and relay, so I have put them next ot the batteries again. The way it is now could stay forever, or until I get some time to work on it again. I have gotten very busy with my work.
  20. bisco
    52,809
    it's great how quickly you accomplished everything. there's a poor guy over on the C forum waiting and waiting for parts to trickle in. it's been about 2 months. he's very upbeat, but yours went much quicker and more smoothly.
