Installed kit from Plug in Supply getting 28 miles!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jim335, Oct 6, 2012.
  1. bisco
    52,878
    any update jim? how is pis doing with thier website?
  2. lensovet
    2,615
    496
    Burlington, NJ
    52,878
    at least they got to first base.:cool:
  4. John H
    John H Senior Member
    2,208
    558
  5. lensovet
    2,615
    496
    Burlington, NJ
    Nice catch. Has the weight on there too, basically 95 lbs.
    I have to say though, at $6500 for a fully-assembled kit, it's pretty steep. Even if you end up getting an extra 15 miles of range, that's saving 0.3 gallons of gas per charge. Even at $4/gal gas, that's only $1.20/charge. So you need to charge over 5,000 times (!) to get the money back. Or 14 years.
    Even at $7/gal gas, we're looking at an 8+-year payback period…
  6. bisco
    52,878
    it's definately not about the payback. if it's plug n play, i spose they'll get a few takers. i would spend $2,000. for an extra 5 miles, but i'll probably wait for the next iteration.
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    lensovet likes this.
  8. bisco
    52,878
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    and.....contrary to popular belief, requires a separate charger as jim stated in this thread
  10. bisco
    52,878
    should come with charger included.
  11. hill
    9,041
    The truly best scenario would be if it recharged off the PiP's on-board charger.
    SGH-I717R ? 2
  12. John H
    2,208
    558
    I would want a seperate charger, tapped into the same J1772 socket, so that both packs could charge in parallel on an L2 charging station/EVSE.
    I suppose charging serially on an L1 EVSE would be fine for overnight charging.
  13. bisco
    52,878
    with two different battery chemistries, is that even possible?
  14. lensovet
    2,615
    496
    Burlington, NJ
    The outlet has no idea what chemistry is in the battery…BMS takes care of that.
  15. bisco
    52,878
    does the bms come with the kit?
  16. lensovet
    2,615
    496
    Burlington, NJ
    Yeah
  17. bisco
    52,878
    so one charger can charge two different batteries at the same time if everything is wired together?
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    according to jim in his earlier posts he tried to charge the pis batteries with the PIP oem charger and it failed
  19. bisco
    52,878
    i wonder if he did it correctly?
  20. bisco
    52,878
    btw, if you go to installation instructions, it tells you it's the same as gen III. that's all that's there. if you go to gen III installation instructions, there are pictures of parts, but no instructions.
