Installed kit from Plug in Supply getting 28 miles!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jim335, Oct 6, 2012.
  1. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    so what happens when your EV range is gone? your motor DOES NOT START? I just dont get it..lol
    Is there another screen to show the new battery SOC? how do you know when its gone?
    any pics of how it plugs in?
    I know the EV range takes along time to adjust, mine was 11.9 for longest time but slowly got up to 14.2 cause i take a slow conserving route.
    Dan
  2. jim335
    jim335 Member
    100
    50
    pa
    I believe toyota uses conservative programming for all controls in the car. It sees the large desparity but adjusts conservatively. Probably a safe approach.
  3. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    Jim, do you use a ScanGauge 2? Does it show SoC of both stock batteries and the PIS?
  4. jim335
    jim335 Member
    100
    50
    pa
    Works the same as always, but takes about twice as long to go away. I drive 5 miles, only lose 2.5 miles of Ev range. I drive 10 miles only lose 4.5 miles and so on. When I reach zero on comes the engine, same as before.
  5. jim335
    jim335 Member
    100
    50
    pa
    I don't have a scan gauge II, but am considering getting one. It would see only the stock battery.
  6. rockerdan
    427
    83
    Wheatfield NY
    ahhhhh OK now i get it! thanks for explaining..very cool,
    this way it will eventually get to show the proper range for sure over enough time. very cool stuff
    i want one!(y)(y)
  7. jim335
    jim335 Member
    100
    50
    pa
    Contact Robb at plug in supply, Tell him I sent you. Maybe he will send me a thank me note.
  8. rockerdan
    427
    83
    Wheatfield NY
    I wish i could afford that right now.....i only spend 30 bucks/mt now on fuel so it would take like 11 yrs to pay for itself at 4k....
    but i still want one! lol
    Dan
  9. bisco
    52,876
    great job jim, looks great! do you know if this is on their website yet, or is it still just just the regular prius?
  10. rockfeller
    rockfeller Junior Member
    88
    CA
    Same here,...........Wait and see for low price. , Under 2k for everything work for me.
  11. jim335
    jim335 Member
    100
    50
    pa
    look on diy site of plug in supply
  12. bisco
    52,876
    just did, couldn't find anything, just non plug in. what am i missing? don't see it in pricing either.
  13. jim335
    jim335 Member
    100
    50
    pa
    $30 per month, not bad. What do you think you would spend if you had regular prius
  14. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    Price really is my only issue as well, as I am surprised as to how little cargo room it uses.
  15. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    try your states daily 4 lottery, Michigan's Daily 4 is $5k
  16. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
  17. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  18. 9G-man
    1,273
    194
    Atlanta, GA
    Why is the kit advertised as "no charger required" How would the PS battery get charged if the PiP charger can't deal with it?
  19. rockerdan
    427
    83
    Wheatfield NY
    well im at a 50/50 EV ratio now......so i guess double with a non PiP correct? so about 65 or so?
    the thing is i was going to buy a non PIP...but got the PIP for only 240 bucks more then non pip....so i could not pass that up.
    Dan
  20. rockfeller
    88
    CA
    Some answers appreciated:
    ===========From Crystal=============
    Thank you for your inquiry.
    and now, I need to konw where do you use the battery pack,
    and what is the continous discharge current and Max. pulse discharge current?
    which voltage and capacity do you want?
    After your answers, we can find the better battery solution for you.
    Looking forward to your early reply.
    Best wishes.
    Crystal
